[FAQ] PCM9211: Recommendation for ADC input connection when ADC is not used
Part Number: PCM9211
What is recommended ADC input connection when ADC is not used?
Ravi
  • For PCM9211 unused pins, follow the below convention -
    - Ground all unused DIGITAL inputs.
    - Do not ground unused ANALOG inputs (but you may connect them to a 100nF cap to GND).
    No power supply is required for the VCCAD pin & VCCAD should be connected to AGND.
    Ravi
