  • TI Thinks Resolved
NE5532: power interference
Expert 2685 points
Part Number: NE5532
Hi Sir,
Since iaccord antecedent is turned on/off,Headphones can hear a momentary "voltage" sound. How to solve the issue? Pls give some recommendation.
Thanks a lot.
BR
Sara
  • Sara,
    Could you provide a circuit schematic in order to have a better approach to this issue?
    Do you know if the power supplies are stable and there's no ripple or noise added in the power lines? Does this issue appear when the analog inputs are connected to GND?
    Luis Fernando Rodríguez S.
  • In reply to Luis Fernando Rodriguez S.:
    Hi Luis,
    Thanks for your reply.
    the schematic is as follow:
  • In reply to Sara Jia:
    Hi, Sara,
    Thank you for providing the NE5532 schematic portion.
    Do the NE5532 inputs have a voltage level when the NE5532 is powered on? If the Ferrite beads FB2, FB3, FB4 and FB6 are removed, do you have the same results?
    Thank you!
    Hi Luis,
    During working status, NE5532 is powered on continuously. Only switch the iaccord antecedent for XLR docking equipment.
    Thanks a lot.
    Hi, Sara,
    In order to avoid this kind of "sounds", when an analog input is modified, it is important to verify that all the decoupling capacitors are discharged slowly and there's no a quick voltage modification.
    Could you provide a scope capture of the NE5532 input voltage when the iaccord is changed for XLR docking equipment? It is just to verify how the input voltage changes at the NE5532 input.
    Hi Luis,
    the scope capture is as follow,
    Pls give me some recommendation on selection to DC blocking capacitors.
    Thanks a lot.
    BR
    Sara
    Hi Sir,
    Any update.
    Thanks a lot.
    BR
    Sara
    Hi, Sara,
    Regarding the XLR connection, is it also referenced to the same ground level than the board?
    In addition, I see a 48V bias in your circuit design. Is it modified during the XLR connection? Does this value also changes?
    Hi, Sara,
    Excuse me, do you have a feedback on this?
