  • TI Thinks Resolved
LM4950: Some questions
Guru 11535 points
Part Number: LM4950
Hi Sirs,
Sorry to bother you.
If we use LM4950, speaker is 4ohm/2w (Use SE)
Is it based on the following figure to determine the output voltage??
The AMP front-end input (AUDIO CODEC output) should be 1.2~1.1 Vrms
Will the setting of gain as shown below be correct ??(speaker is 4ohm / 2W)
  • Hi, Shu-Cheng,
    Please take a look at my responses below and let me know if you have additional questions or comments on it.
    If we use LM4950, speaker is 4ohm/2w (Use SE) Is it based on the following figure to determine the output voltage??
    Yes, figure 23 of datasheet shows the output power that you may reach for a RL = 4ohms (SE operation) with a THD+N = 10% and THD+N = 1%. You would need to select the power supply according to your power requirements.
    This resistors configuration results in a gain of ~16.3. Could you provide details about the input that you will be using and the expected output?
    Luis Fernando Rodríguez S.
  • In reply to Luis Fernando Rodriguez S.:
    Hi Sirs,
    Thanks for your reply.
    Please help confirm the LM4950 schematic (Single-Ended)
    LM4950_0815-Edit.pdf
    The line below CN9 is anti-pops
    Input spec as follows
  • In reply to Shu-Cheng LIN:
    Hi Sirs,
    Have any update on here?
    Thanks!!
    Hi, Shu-Cheng,
    Sorry for the delay on this.
    I already reviewed the schematic and everything seems to be in order. I didn't find anything to modify.
    The configured gain in this case is given by Rf / RI = (48.7K / 20K) = 2.435. If a 1.2 Vrms signal is used, you should be able to reach almost 2.9Vrms at the output. This would be enough to reach 2W output power with a 4ohms load.
