In the example configuration in CodecControl application for TAS2505EVM there are lines described as LDAC / RDAC channel configuration (register page = 0x00):
Writing to register 0x3F: data 0xB0 means 1011 0000. D5=1; D4=1 -> datasheet says: “DAC data is picked from Mono Mix of Left and Right”, but in the script comment it is written that only LDAC is used.
Writing to register 0x40: data 0x04 means 0000 0100. D2=1 -> datasheet says: “Reserved…”, but in the script comment it is written that it means “Right DAC muted”.
Can you advise how to read this correctly?
Thank you.
