  • Resolved
[FAQ] PUREPATHCONSOLE: PurePath Console 3 gets stuck while initializing the device
Mastermind 46725 points
Part Number: PUREPATHCONSOLE
In this FAQ you will find a couple solutions to fix the PPC3 stuck symptom during device initialization:
  • You can use a previous version of the installer, it can be downloaded from the attachment
  • You can also check if environment variables are correct on your system by following these sides
Hope this workaround helps you to proceed with your device evaluation. We're currently working on a new installer release to fix this issue.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
  • If you tried the above and still having problems, please don't hesitate to past a new thread on the forum so we can take a look.
    -Ivan Salazar
