Other Parts Discussed in Thread: OPA1632
Hi Team,
Would you advise about below two questions?
1. There is a description of "Each analog input pair accepts a full-scale input voltage of
approximately 6.0VPP differential on page 13 of datasheet.
However when Vcc is 5V, input D range will be 5V.
In this case, we should input with D range from 0V to 5V.
Is this understanding right?
2. Although it is an analog input terminal, it is biased internally.
Is it OK to insert a coupling capacitor and input a signal that swings to +/- around zero volts?
Shidara
