TAS2505: About Standby Mode
Part Number: TAS2505
In TAS2505 Application Reference Guide section 2.8.1.2.1 Standby Mode, it is described as follows. Does “all other blocks” mean IOVDD supply? In Section 3.1.2, Power On Sequence 2, the sequence is to turn on AVDD and DVDD after turning on IOVDD. Is it safe to disconnect or connect IOVDD while AVDD and DVDD or SPKVDD is on? Is it okay to keep SDA and SCL pulled up with IOVDD disconnected for the interface with HOST PROCESSOR in Figure 1-3? When IOVDD is disconnected, is the output signal DOUT from TAS2505 required to be pulled down? best regards
