Dear Sir,
Accordint to TPA3251 datasheet description, it can achieve 175W stereo into 4 ohm in BTL configuration. I don't know how to calculate out the number of 175W.
Genie
Dear Sir,
Genie
Hi Genie,
As a sine wave, the RMS value equals to Vpeak/√2,.
PVDD=36V, Rload = 4Ohm, if there is no clipping, Pout = (36/√2)^2 / 4(Ohm) = 162W. This is ideal output power without clipping. Output power can go higher, but output voltage will be clipped and THD+N get worse.
175W given on datasheet is the typical output power when THD+N=10%. You may refer to figure 3 on datasheet.
Hao
Dear Hao,
Because it's BTL configuration, shouldn't Vpeak be two times PVDD? That's what I found from Internet.
Genie
Hi Genie,
The AC voltage applied across the loading is a sine wave with Vp=PVDD, Vp-p=2*PVDD. While for a sine wave, the RMS voltage is Vp/√2.
Hao
Dear Hao,
Could you figure out whta the output power is while operating in single end configuration and 4 ohm load?
Genie
Hi Genie,
For single-end configuration,
If PVDD=36V, Voltage across the speaker slews from 0V to 36V, then Vp=18V, Vrms=18/√2. No clipping max power is (18/√2)^2 / 4= 40.5W.
Hao
According following picture, I have some questions.
1. What kind of audio signal is? Is it a sinusoidal or an analog waveform?
2. What does the audio amplifier output waveform look like when connecting in single-ended configuration?
3. What does the audio amplifier output waveform look like when connecting in BTL configuration?
Genie
1. Audio signal can be anything within audio frequency range, including the sine wave.
2. In single-end configuration, the speaker is connected across GND and output. With 36V PVDD, the output can swing from 0 to 36V, making a sine wave with 36Vp-p (18Vp).
3. In BTL, the speaker is connected across OUTP and OUTN. With 36V PVDD, the output can swing from -36V to 36V, making a sine wave with 72Vp-p (36Vp).
Hao
Dear Hao,
If input is a sine waveform, no matter it's single-ended or BTL configuration, output waveforms are also a sine wave, right?
With 36PVDD, in single-ended, output is a 36Vp-p sine waveform and BTL output is a 72Vp-p sine wavefrom, Am I understanding correct?
Genie
Hi Genie,
Yes, your understanding is correct. The key point here is in BTL, the output can swing from -PVDD to +PVDD, while in SE, the output can only swing from 0 to PVDD.
Hao
Dear Hao,
1. If there is a positive input signal (without negative content) feeding into BTL configuration, does the output still swing from -PVDD to +PVDD?
2. if there is a sine wave input signal (including positive and negative content) feeding into SE configuration, due too output can only swing from 0 to PVDD, does that mean the negative content of input signal will disappear on output?
Genie
1. No. Positive in, then positive out.
2. The output will swing on both sides of 1/2 PVDD. Positive will be higher than 1/2PVDD, then negative lower than 1/2PVDD.
Hao
