Hi TI-team
Do you have a detailed circuit block diagram ?
In the block diagram, only the attenuator, mixer, and class D amplifier are found in the analog path.
I think that an oscillator and a comparator are used.
Koji Hayashi
Hi TI-team
Koji Hayashi
Hi, Hayashi-san,
The only block diagram that we have is located in the main page of the datasheet:
http://www.ti.com/lit/ds/symlink/tas2505-q1.pdf
I think you refer to the details for the delta sigma modulator. You may find more details about the delta sigma behavior in these documents:
http://www.ti.com/lit/an/slyt423a/slyt423a.pdf
http://www.ti.com/lit/an/slyt438/slyt438.pdf
Please notice that these documents refer to the ADC behavior. In case of the delta sigma DAC, the diagram would be inverted. I mean, the signal data will start with an interpolation filter, then the digital filer and finally the delta sigma modulator. For further details about the interpolator filter and the digital filters, please consult the section 2.4.1.1 from the reference guide:
http://www.ti.com/lit/ug/slau472/slau472.pdf#page=10
I hope this helps you. Please let me know if you have additional questions or comments on this.
Luis Fernando Rodríguez S.
Hi Luis-san
Thank you for quick response.
I understand that there is no detailed block diagram.
I will contact the customer.
Koji Hayashi
