Dear TI :
We have used the TAS2557 at our product and will SMT on 5/15.
We will refer the document "TAS2557 Factory Test and Calibration Guide.pdf".
Can you provide the calibration tools for factory ?
Dear TI :
Hi Rence,
You can find the factory test and calibration files in our repository along with the driver: https://git.ti.com/cgit/tas2557sw-android/tas2557-ftc/
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Ivan ,
I refer to the TAS2557 Factory Test and Calibration Guide.pdf , and I can not find this file "factorytest_readme.txt" of installation informations.
2 Factory Test Application
For installation and detailed usage, please refer to factorytest_readme.txt.
Could you help to provide it for us, or help to introduce the installation informations?
Thank you.
Jinjia Wu
Hi Ivan ,
I refer to the TAS2557 Factory Test and Calibration Guide.pdf , and I can not find the "factorytest_readme.txt" about installation informations.
Could you help to provide it, or help to introduce the installation informations?
Thank you.
Jinjia Wu
Hi Jinjia,
The file name is Readme.txt
You can find it here: https://git.ti.com/cgit/tas2557sw-android/tas2557-ftc/tree/readme.txt
-Ivan Salazar
Hi Ivan ,
How to install Factory Test Application for generate a bin file "tas2557_cal.bin".
Is integrated this tas2557-ftc driver into the source code, then build in the Factory Test Application into android device after download the image?
e.g. kernel/msm-4.9/.../tas2557-ftc/ , or vendor/.../tas2557-ftc/?
Thank you.
Jinjia Wu
Hi Ivan ,
I implemented the driver: git.ti.com/.../ ,and executed successfully.
But when I adjust the volume(adjust ring volume via volume key), the value "DevA Re" will change.
The value of each test is different (as shown in the picture).
I think the value should be not change on the same device.
How to judge whether the calibration data is correct?
Thank you
Jinjia Wu
Hi Ivan ,
The ring volume in Settings/Sound/Ring volume.
Now the value range of DevA Re is not large after we adjust the tas2557evm_aacspk_a.ftcfg. (8.28~9.27 ohm ==> 7.35~7.37 ohm)
But I find a new issue, tas2557 driver can not find the TAS2557 calibration files ,error msg as below:
12031 06-17 11:43:11.667 0 0 I tas2557 6-004c: TAS2557 calibration file = data/tas2557_cal.bin, handle = -13 12033 06-17 11:43:11.667 0 0 E tas2557 6-004c: TAS2557 cannot open calibration file: data/tas2557_cal.bin 12035 06-17 11:43:11.667 0 0 E tas2557 6-004c: Calibration 0 doesn't exist
And we are sure that the files exist in device.
Please help us to clarify the issue.
Thank you.
Jinjia Wu
