can TPL5110 used in the below case:
when the time less than 30s, the output is follow with input signal, and when the time higher than 30s, the output is low.
I promote the TPL5110, but one question is in the datasheet, the DRV output signal is the pulse, can it use in this applicaiton? or do you have any good recommendation?
thank you.
