  • Resolved
Conversion product from capacitance to PWM clock
Intellectual 2480 points
Hello support team,
My customer is looing for Conversion product from capacitance to PWM clock. Could you tell me your suggestion?
Cap range: 1pF up to 50pF
Expected output frequency: 150 or 160kHz to 200kHz. (1k Hz per 1pF)
Koji Ikeda
  • Koji,
    The FDC2214 can provide a digital capacitance output, but you would need to pair it with an MCU to create a PWM output signal.
  • In reply to Clancy Soehren:
    Clancy-san,
    Thank you for your support. I don't see FDC2214 on TI.com product seach, can FDC2214 provide proper support now?
    www.ti.com/.../products.html
    And additional MCU is not good for system. Do you have any ohter solution?
    Koji Ikeda
  • In reply to Koji Ikeda:
    Koji,
    There is no other option for a PWM output as you described. We do have devices that have interrupt output pins that will indicate when the data crosses a certain threshold.
    If you search directly for the part number, then you can find the product folder. It is here:
    www.ti.com/.../FDC2214
    Clancy-san,
    I have another question, can timer IC like LMC5555 support their usage? Timer IC is very popular for PMW generator.
    Koji Ikeda
    Koji,
    The FDC2214 supports I2C output. I do not think that you can convert this to PWM using a 555 without an intermediate step.
