Other Parts Discussed in Thread: DAC3484EVM, LMK04832,
So I'm trying to use this card in a setup. I've input a 10MHz, 1.3Vpp squarewave/sinewave (I've tried both), 0-1.3V as well as tried +/-0.65Vpk. Set up DCLK0 to output 153.6MHz LVDS and cannot see a signal of any recognition to this output. I have the output SMA connections +/- connected with equal length SMA to SMA cables to an ADC-WB-BB Balun. The output of the Balun is connected to the CLKIN input on J9 of a DAC3484EVM. I'm seeing a very jittery signal output with little or no semblance of the desired signal. The D4 LED is lit but the D5 LED is not. This tells me that PLL1 may be locking but PLL2 is not. I'm guessing as to what's happening here. Attached is the setup for this card.
[SETUP] ADDRESS=888 CLOCK=8 DATA=4 LE=2 PART=LMK04828B IFACE=SPI ADDRESS_I2C=0x0 [PINS] PINNAME00=SYNC LOCATION00=7 PINVALUE00=False PINNAME01=CLKin0_SEL LOCATION01=0 PINVALUE01=False PINNAME02=RESET LOCATION02=3 PINVALUE02=False [MODES] NAME00=R0 (INIT) VALUE00=144 NAME01=R0 VALUE01=16 NAME02=R2 VALUE02=512 NAME03=R3 VALUE03=774 NAME04=R4 VALUE04=1232 NAME05=R5 VALUE05=1371 NAME06=R6 VALUE06=1536 NAME07=R12 VALUE07=3153 NAME08=R13 VALUE08=3332 NAME09=R256 VALUE09=65556 NAME10=R257 VALUE10=65877 NAME11=R258 VALUE11=66133 NAME12=R259 VALUE12=66305 NAME13=R260 VALUE13=66562 NAME14=R261 VALUE14=66816 NAME15=R262 VALUE15=67321 NAME16=R263 VALUE16=67345 NAME17=R264 VALUE17=67608 NAME18=R265 VALUE18=67925 NAME19=R266 VALUE19=68181 NAME20=R267 VALUE20=68352 NAME21=R268 VALUE21=68610 NAME22=R269 VALUE22=68864 NAME23=R270 VALUE23=69369 NAME24=R271 VALUE24=69381 NAME25=R272 VALUE25=69640 NAME26=R273 VALUE26=69973 NAME27=R274 VALUE27=70229 NAME28=R275 VALUE28=70400 NAME29=R276 VALUE29=70658 NAME30=R277 VALUE30=70912 NAME31=R278 VALUE31=71409 NAME32=R279 VALUE32=71424 NAME33=R280 VALUE33=71704 NAME34=R281 VALUE34=72021 NAME35=R282 VALUE35=72277 NAME36=R283 VALUE36=72448 NAME37=R284 VALUE37=72706 NAME38=R285 VALUE38=72960 NAME39=R286 VALUE39=73457 NAME40=R287 VALUE40=73523 NAME41=R288 VALUE41=73736 NAME42=R289 VALUE42=74069 NAME43=R290 VALUE43=74325 NAME44=R291 VALUE44=74496 NAME45=R292 VALUE45=74754 NAME46=R293 VALUE46=75008 NAME47=R294 VALUE47=75505 NAME48=R295 VALUE48=75520 NAME49=R296 VALUE49=75784 NAME50=R297 VALUE50=76117 NAME51=R298 VALUE51=76373 NAME52=R299 VALUE52=76544 NAME53=R300 VALUE53=76802 NAME54=R301 VALUE54=77056 NAME55=R302 VALUE55=77561 NAME56=R303 VALUE56=77568 NAME57=R304 VALUE57=77830 NAME58=R305 VALUE58=78165 NAME59=R306 VALUE59=78421 NAME60=R307 VALUE60=78592 NAME61=R308 VALUE61=78850 NAME62=R309 VALUE62=79104 NAME63=R310 VALUE63=79601 NAME64=R311 VALUE64=79667 NAME65=R312 VALUE65=79909 NAME66=R313 VALUE66=80128 NAME67=R314 VALUE67=80396 NAME68=R315 VALUE68=80640 NAME69=R316 VALUE69=80896 NAME70=R317 VALUE70=81160 NAME71=R318 VALUE71=81411 NAME72=R319 VALUE72=81672 NAME73=R320 VALUE73=82109 NAME74=R321 VALUE74=82176 NAME75=R322 VALUE75=82432 NAME76=R323 VALUE76=82705 NAME77=R324 VALUE77=82947 NAME78=R325 VALUE78=83327 NAME79=R326 VALUE79=83472 NAME80=R327 VALUE80=83730 NAME81=R328 VALUE81=83970 NAME82=R329 VALUE82=84290 NAME83=R330 VALUE83=84482 NAME84=R331 VALUE84=84758 NAME85=R332 VALUE85=84992 NAME86=R333 VALUE86=85248 NAME87=R334 VALUE87=85696 NAME88=R335 VALUE88=85887 NAME89=R336 VALUE89=86019 NAME90=R337 VALUE90=86274 NAME91=R338 VALUE91=86528 NAME92=R339 VALUE92=86784 NAME93=R340 VALUE93=87160 NAME94=R341 VALUE94=87296 NAME95=R342 VALUE95=87587 NAME96=R343 VALUE96=87808 NAME97=R344 VALUE97=88214 NAME98=R345 VALUE98=88323 NAME99=R346 VALUE99=88576 NAME100=R347 VALUE100=89055 NAME101=R348 VALUE101=89120 NAME102=R349 VALUE102=89344 NAME103=R350 VALUE103=89600 NAME104=R351 VALUE104=89867 NAME105=R352 VALUE105=90112 NAME106=R353 VALUE106=90369 NAME107=R354 VALUE107=90660 NAME108=R355 VALUE108=90880 NAME109=R356 VALUE109=91136 NAME110=R357 VALUE110=91406 NAME111=R369 VALUE111=94634 NAME112=R370 VALUE112=94722 NAME113=R380 VALUE113=97301 NAME114=R381 VALUE114=97587 NAME115=R358 VALUE115=91648 NAME116=R359 VALUE116=91904 NAME117=R360 VALUE117=92174 NAME118=R361 VALUE118=92509 NAME119=R362 VALUE119=92704 NAME120=R363 VALUE120=92928 NAME121=R364 VALUE121=93184 NAME122=R365 VALUE122=93440 NAME123=R366 VALUE123=93715 NAME124=R371 VALUE124=94976 NAME125=R8189 VALUE125=2096384 NAME126=R8190 VALUE126=2096640 NAME127=R8191 VALUE127=2096979 [FLEX] bSetFeedback_CLKin1=CLKin1 (External) bSetFeedback_DCLKout6=DCLKout6 bSetFeedback_DCLKout8=DCLKout8 bSetFeedback_SYSREFDIV=SYSREF divider bSetJESD204B_Continuous=Continuous bSetJESD204B_NoJESD204B_withoutSYSREFDivider=No JESD204B bSetJESD204B_Pulser=Pulser bSetJESD204B_Reclocked=Reclocked bSetJESD204B_SYSREFREQ=SYSREF Request bSetMode_Distribution=Set Distribution bSetMode_DualLoop=Set Dual Loop bSetMode_DualLoop0DelayCascaded=Set Dual Loop 0-Delay Cascaded bSetMode_DualLoop0DelayNested=Set Dual Loop 0-Delay Nested bSetMode_SingleLoop=Set Single Loop bSetMode_SingleLoop0Delay=Set Single Loop 0-Delay bSet_CLKin0toOff=CLKin0 Off bSet_CLKin0toPLL1=CLKin0 drives PLL1 bSet_CLKin0toSYSREF=CLKin0 drives SYNC/SYSREF bSet_CLKin0toSYSREF_Direct=CLKin0 drives SYNC/SYSREF direct bSet_CLKin1_ExternalVCO=CLKin1 drives Clock Distribution (external VCO/distribution mode) bSet_CLKin1toOff=CLKin1 Off bSet_CLKin1toPLL1=CLKin1 drives PLL1 bSet_CLKin2_Input=CLKin2 for PLL1 CLKDIST_FREQ=3071.992 CLKin0_FREQ=122.88 CLKin1_FREQ=10 CLKin2_FREQ=153.6 CLKin_SEL_AUTOPINSMODE=1 EXT_VCXO_FREQ=109.714 FB_MUX_FREQ=127.9996666667 FB_MUX_FREQ_MHz=MHz OSC_FREQ=109.714 OSCin_SOURCE=0 PLL1_PD_FREQ=0.285714285714286 PLL2_PD_FREQ=109.714 PLL_FBMUX_WARNING_TEXT=0 PLL_WARNING_TEXT=0 WARNING_TEXT_PLL1= WARNING_TEXT_PLL2= CLKDIST_FREQ=3071.992 SYSREF_FREQ=0.9999973958 bSYNC_DIS_AllOff=All Off bSYNC_DIS_AllOn=All On bSYNC_DIS_CLKOff=DC Off bSYNC_DIS_CLKOn=DC On bSYNC_Dividers=SYNC Dividers bSendPulsesViaSPI=Send Pulses bSetJESD204B_Continuous=Continuous bSetJESD204B_Pulser=Pulser bSetJESD204B_RX_CLKin0=CLKin0 bSetJESD204B_RX_CLKin0_Bypass=CLKin0 Bypass bSetJESD204B_RX_Ignore=None bSetJESD204B_RX_Reclocked=Re-Clocked bSetJESD204B_RX_SYNCpin=SYNC Pin bSetJESD204B_SYSREFREQ=SYSREF Request bSetSYNC_Normal=Normal stSYSREF_CLR_WARNING= CLKDIST_FREQ=3071.992 CLKout0_FREQ=153.5996 CLKout10_FREQ=383.999 CLKout11_FREQ=383.999 CLKout12_FREQ=511.9986666667 CLKout13_FREQ=511.9986666667 CLKout1_FREQ=153.5996 CLKout2_FREQ=127.9996666667 CLKout3_FREQ=127.9996666667 CLKout4_FREQ=383.999 CLKout5_FREQ=383.999 CLKout6_FREQ=127.9996666667 CLKout7_FREQ=127.9996666667 CLKout8_FREQ=383.999 CLKout9_FREQ=383.999 OSCout_FREQ=109.714 SDCLKout11_TEXT=0 SDCLKout13_TEXT=0 SDCLKout1_TEXT=0 SDCLKout3_TEXT=0 SDCLKout5_TEXT=0 SDCLKout7_TEXT=0 SDCLKout9_TEXT=0 SYSREF_FREQ=0.9999973958
