Dears.
Dears.
The LMK04826 has been designed and doing test.
REF_CLK = 10Mhz.
10Mhz is supplied by Signal Generater.
When 10Mhz level is less than 5dBm, PLL lock does not work.
Even if R344 is removed and a 10Mhz level is input up to 0dBm, it becomes PLL Lock.
Why does the PLL Lock level differ?
Is 50 Ohm necessary?
How do I get a 10Mhz level to -3dBm to PLL lock?
Thank you
