Team,
- Based off the following lines of the datasheet, the output voltage supply cannot exceed the core voltage supply. What are the consequences if it does?
- Is there a way to configure this part as an inverting buffer while using a single ended input? Can this be done by using the recommended input configuration in the datasheet, but feeding the input clock to the CLKin- pin?
Thank you.
