Hello
I am looking for output power at 2.5GHz.
Can you please confirm? Is the power in single ended or differential?
The mixer is singled ended an takes in 0dBm +/-6dB. They recommend a series DC block cap.
Can someone please recommend which is the best balanced topology ie balanced attenuator (pi or T) , discrete LC Balun or off the shelf Balun (please recommend in this case).
In case of balanced, when it reaches the mixer, one side of attenuator Will be gnded via cap. Other side goes to LO
