• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Clocks & Timers » Clocks & Timers Forum » Clock Distribution Network
Share
Clocks & Timers
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question has suggested answer(s)
Irfan Awan
Posted by Irfan Awan
on Feb 15 2012 09:15 AM
Prodigy230 points
Hi All,
We are working on development of IR UWB positioning system . This  system is similar to system presented  in  IEEE paper
"UWB-based Local Positioning System from a small-scale Experimental Platform to a large-scale Deployable System"
In our system we have to distribute 26 MHz clock as reference clock among the four base station .
Distance between two base stations is 10 meter. The clock will be distributed off broad  via twisted pair cable.
Can anyone please suggest  any suitable product from TI clock and timing product  for our solution.
Clock requirements
26 MHz
+- 5 ppm
Kind Regards
Irfan Awan
Marna Tech AB
Stockholm Sweden
Phone +46736160016
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Alan Ocampo
    Posted by Alan Ocampo
    on Feb 15 2012 11:55 AM
    Expert4160 points
    7206.LMK04110_26MHz-TCXOref_26MHz-LVPECLout.savHi Irfan,
    What are you phase noise or jitter requirements with integration bandwidth?
    Based on the frequency accuracy requirement, you'll at least need a TCXO as your reference clock.  Depending on your phase noise/jitter requirements, you could consider the following approaches:
    1. If you can find a 26 MHz, +-5 ppm TCXO that already meets your phase noise/jitter requirements, then you could use a low-noise clock fanout buffer/level translator with differential outputs for driving a twisted-pair cable.  One example is the LMK00301, which has 2 banks of 5 differential outputs (LVPECL/LVDS/HCSL) and universal inputs (single-ende/differential).  A 4-output version of this device will be available soon.
    2. If you need better phase noise at higher offset frequencies (e.g. > 50 kHz), then you could use a TCXO as a reference clock to feed a clock jitter cleaner.  One example is to use the LMK04110 (5 LVPECL outputs) with the TCXO feeding the reference input to PLL2, which uses an integrated low-noise VCO with better high-offset phase noise than the TCXO.  The output divider has a very low broadband phase noise floor of about -160 dBc/Hz.
      1. Attached is a simulation file for National's Clock Design Tool, which shows the LMK04110 configuration with PLL2 only (PLL1 not used) and an example 26 MHz TCXO reference.  The 26 MHz TCXO phase noise was modeled using the 10 MHz phase noise plot in the datasheet below, with the phase noise scaled up by +8 dB (=20*log10(26 MHz/10 MHz) ).
      2. CTS 26 MHz TCXO: http://www.ctscorp.com/components/Datasheets/008-0324-0.pdf
    Alan
    Report Abuse
    • Reply
  • Irfan Awan
    on Feb 16 2012 06:44 AM
    Prodigy230 points
    Hi Alan,
    Thanks for your reply.
    We are using  four channels of IEEE802.15.4a  which are ch1.ch3.ch4.ch7 with center frequencies 3494.4 ,3993.6,4492.8 and 6489.6 MHz respectively  .
    Large channel spacing and spectral mask relax Phase Noise requirements for PLL.
    Sorry I do not have exact number about Phase Noise .
    What you suggest still the solution you proposed will be valid ,
    Can you suggest any evaluation board which have both TCXO and Buffer.
    Irfan
    Report Abuse
    • Reply
  • Alan Ocampo
    on Feb 16 2012 13:57 PM
    Suggested Answer
    Expert4160 points
    Hi Irfan,
    The LMK00301 10-output differential clock buffer can be ordered here: http://www.national.com/pf/LM/LMK00301.html#Boards.  As I mentioned before, a 4-output version of this device will be released soon.  Performance and functionality will be very similar.
    The evaluation board does not include the 26 MHz TCXO.  However, it does have a 3.2 x 2.5 mm footprint (Y2) for a SMD crystal, which could accomodate a TCXO in the same package.  You would need to disconnect the crystal Y1 and its load capacitors, and then install the TCXO with the proper connections.  TCXO pins 1 & 2 = tie to GND, pin 3 = Output ac-coupled to OSCin pin, pin 4 = tie to VCC with nearby bypass cap).
    I found a couple 3.3 V TCXOs in 3.2 x 2.5 mm footprint on Digi-key.
    • 7Q-26.000MBS-T  (datasheet: http://www.txccrystal.com/images/pdf/7q.pdf)
    • D32G-026.0M  (datasheet: http://www.conwin.com/datasheets/tx/tx240.pdf)
    Alan
    Report Abuse
    • Reply
  • Irfan Awan
    on Apr 20 2012 11:32 AM
    Prodigy230 points
    Hi Alan,
    I was waiting for 4-output version of LMK00301 device. I guess LMK00304 is that . I try to order that online by Mouser . The shipping time to Sweden was 8 weeks.
    We want  the evlation board for LMK00304 in 2 week , Can you please tell any alternative ? Like placing order directly to TI or any other solution.
    Irfan Awan
    Report Abuse
    • Reply
  • Alan Ocampo
    on Apr 20 2012 12:34 PM
    Expert4160 points
    Hi Irfan,
    You can order the LMK00304EVM directly from TI via the tool folder: http://www.ti.com/tool/lmk00304evm
    Just click the "Order Online" button.  You will need to be logged in to your ti.com account.  The user guide is available here.
    The LMK00304 datasheet and IBIS model is available from the product folder: http://www.ti.com/product/lmk00304
    Alan
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
