• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Clocks & Timers » Clocks & Timers Forum » LMH2180 75 MHz Dual Clock Buffer
Share
Clocks & Timers
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Sam Storm van Leeuwen
Posted by Sam Storm van Leeuwen
on Mar 21 2012 03:29 AM
Prodigy40 points
I am looking for the time delay between Enable on and output active, and between Enable off and output to hi impedance.
Can somebody please help me to get this info? Thanks
Sam
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Timothy T
    Posted by Timothy T
    on Mar 26 2012 11:34 AM
    Suggested Answer
    Expert3900 points
    Hello Sam,
    Measurement on a typical LMH2180 unit in the Lab shows:
        -    Turn-on time from EN Low-High to Output active = ~650ns
        -    Turn-off time from EN High-Low to Output Hi-Z = ~500ns
    Please let us know if you require any further assistance.
    73,
    Timothy
    Report Abuse
    • Reply
  • Sam Storm van Leeuwen
    on Mar 28 2012 03:03 AM
    Prodigy40 points
    Dear Timothy,
    Thank you very much for your clear answer. Unfortunately these time are far to long
    for my application: switching TCXO outputs (25MHz, clipped sine, 0.8Vpp) with switching
    times in the order of a few nsec!! Do yopu have a suggestion for an alternative?
    Sam
    Report Abuse
    • Reply
  • Alan Ocampo
    Posted by Alan Ocampo
    on Apr 05 2012 20:33 PM
    Expert4160 points
    Hi Sam,
    If you require an dual channel analog clock buffer to preserve the clipped sine signal, you could use a dual op amp with low-noise and disable feature in unity-gain configuration.  One possible option is OPA2836 which has a disable time of 25 ns and enable time of 200 ns (typical) at Vs = 2.7 V.
    If you are OK with converting the clipped sine wave to a square wave, the LMK00105 (5 outputs) is a LVCMOS buffer with Hi-Z capability, 1.5 to 3.3V adjustable output supply, and synchronous output enable (OE).  The OE control input is synchronized to the input clock to ensure runt-pulse-free operation when the OE toggled H to L (disabled) or L to H(enabled).  The enable/disable time is 2 input clock cycles typical (3 cycles max).  So with a 25 MHz input clock, the typical enable/disable time will be between 80 to 120 ns.
    Alan
    Report Abuse
    • Reply
    on Apr 08 2012 04:15 AM
    Prodigy40 points
    Hi Alan,
    Thanks for your thorough reply. I do indeed need to preserve the clipped sine property, the processor chip which needs to be clocked requires this. I need to switch from one clock to another. I can't however miss any clock cycle, that's why I am looking for devices with enable/ disable times in the order of a few nanoseconds. I may have found CMOS switches which do have this property. Do you have alternative suggestions?
    Again, thanks
    Sam
    Report Abuse
    • Reply
  • Alan Ocampo
    on Apr 09 2012 14:55 PM
    Verified Answer
    Verified by Timothy T
    Expert4160 points
    Hi Sam,
    A high-speed analog switch/multiplexer could provide the fast switching you're looking for, but make sure that the off-isolation and crosstalk performance is sufficient for your application especially if the two input clocks you are switching are at different frequencies and/or non-synchronous.
    TI has a wide portfolio of these parts, which can be found through the links below:
    Analog Switch (Vs <= 5V) Product Tree: http://focus.ti.com/paramsearch/docs/parametricsearch.tsp?familyId=614&family=logic&uiTemplateId=SZVI_T
    Analog Switch (Vs > 5V) Product Tree: http://focus.ti.com/paramsearch/docs/parametricsearch.tsp?familyId=1510&family=logic&uiTemplateId=SZVI_T
    Analog Switch Guide: http://www.ti.com/lit/sg/slyb125c/slyb125c.pdf
    Alan
    CMOS switch analog switch
    Report Abuse
    • Reply
    on Apr 10 2012 05:40 AM
    Prodigy40 points
    Hi Alan,
    Yes, I guess that's the way to go. I found one switch with on/ off times in the order of 5nsec, that should do the trick. And thanks for your remarks about cross-talk etc.
    Regards, Sam
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
