• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Clocks & Timers » Clocks & Timers Forum » CDCE62005 practical questions about EEPROM, Loop filter and other things
Share
Clocks & Timers
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Fritz
Posted by Fritz
on Mar 22 2012 16:12 PM
Expert4370 points
Here a Q&A that might be helpful to others:
1) Can the CDCE62005 be purchased preprogrammed to a setting of our choosing?
Yes, through Avnet, who is setup to do this programing for this device.
5) On my design I will not use the secondary input port, what does TI prescribe for tying this unused
port off?
You can disable this input and tie it to GND through a pull-down of a few kΩ on each input leg.
7) Why does TI recommend Y5V vs X7R caps on pins 4 & 38.
The capacitors need to have a particular ESR. I assume we are looking for a low ESR for the internal regulator.
8) What is the range of loopbandwidth (low to high) that I can set the filter to while running at 500MHz with a 25MHz xtal on the aux.
note: my study shows that the range is a function of settings and that the range with my settings ~65kHz=>1GHz.
Loop bandwidth ranges from 30Hz up to fPFD/10, but you should not aim for anything higher than 500kHz. For a 25MHz XTAL, I would recommend aiming for 300kHz (maybe also try 400kHz, as you can all these values by simply using the internal loop filter and reconfiguring).
9) How shall I go about choosing the optimal setting? There are many?
Target the following:
BW=300-400kHz
Phase Margin= aim for 60-70 (65 is great)
Gamma= make it at least one, 10 is best, make it less than 100 I’d say
R3: minimize (e.g. 5k)
C3: set it such that 3rd pole is at least 10x higher than BW (e.g. 3MHz); If in doubt, minimize C3
C1: don’t use less than 10pF
C2: I would use max value at 473.5pF
R2: set it such that you get the right BW, likely 4k or 9k
ICP: make it at least 300uA, I would aim for 600uA if possible with the combinations of the other components.
Here is a setting that would be really good:
10) Is the GUI setup software stable?
YES
11) Can I run the TI setup software with another host adaptor (someone elses spi port tool)?
Not easily, because the GUI tries to access a particular driver inside the USB receiver and there is no documentation how to do this.
12) Can TI recommend a SPI tool?
We do have stand-alone USB dongles that can convert USB into SPI and use the driver from our EVM I believe.
Most customers write their own SPI sequence with a controller.
CDCE62005
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Fritz
    Posted by Fritz
    on Mar 22 2012 16:13 PM
    Verified Answer
    Verified by Fritz
    Expert4370 points
    ok
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
