• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Clocks & Timers » Clocks & Timers Forum » Clock solution providing in phase and 90 / 180 degrees out of phase outputs?
Share
Clocks & Timers
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question has suggested answer(s)
Tom Smith
Posted by Tom Smith
on Apr 17 2012 08:26 AM
Expert2925 points
Customer request;
I have two (or three) power supplies that I would like to sync to an external clock.  This way the power supplies can be run 180 degrees (or 90 degrees) out of phase from each other to reduce ripple current in the power system.
Is there a synchronizer chip that puts out two (or three) clocks that are 180 degree (or 90 degrees) out of phase with each other to take care of this?
The switcher runs at 300KHz but the SYNC pin will take 200KHz – 400KHz.  The input logic levels on the SYNC pin are TTL.  Commercial temperatures should be okay here.
Comments.....
-Tom-
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Timothy T
    Posted by Timothy T
    on Apr 17 2012 13:30 PM
    Expert3900 points
    Hello Tom,
    What is the phase tolerance for 180 degree inversion?  300 kHz has a period of 3.33 us.  Is it possible to use a simple inverter?  Like SN7414 with a propagation delay max of 22 ns.
       - An LVCMOS input clock could drive multiple inputs of the SN7414 at the cost of increased capacitive loading.  The outputs could be direct through 1 inverter for a 180 degree shift or through 2 inverters for the 0 degree shift.
    73,
    Timothy
    Report Abuse
    • Reply
  • Alan Ocampo
    Posted by Alan Ocampo
    on Apr 17 2012 16:36 PM
    Suggested Answer
    Expert4110 points
    LMK04906 (to be released in May 2012) is a lower-cost version of the LMK04806 (released) with fewer outputs and can provide 2 to 12 multi-phase CMOS/TTL outputs at 300 kHz for synchronizing multiple switchers.  Any unused outputs / features may be shut-down to reduce power.  Note that this device was not designed specifically for this application and may be overkill in terms of performance/power/size, but does provide a lot of flexibility/programmability if this is important for system performance optimization.
    LMK04906 Example Use Case for Generating Multiphase SYNC Outputs at 300 kHz
    • Use single-loop PLL2 mode with a low-cost 10 MHz crystal to lock the on-chip VCO to 2.4 GHz (yes, Giga).  The 2.4 GHz VCO can be divided to 300 MHz (distribution bus frequency) using VCO divider=8 and ultimately 300 kHz (output frequency) using output divider=1000.
    • Programmable output drivers allows you to independently configure each output as 3.3 V CMOS with normal or inverted phase (0 or 180 degrees).  To achieve phases between 0 degrees to +/-180 degrees (or slightly beyond), use the programmable digital delay (per channel) and sync features to adjust the delay range from 0 us to 1.723 us (i.e. >180 degrees offset at 300 kHz) with delay step size of 3.333 ns (1 period of 300 MHz bus frequency) or 0.36 degrees/step.
    LMK04906 operates over the industrial temp range and uses a Microwire programming interface (subset of SPI).  Note that minimum VCO tuning range of this device (2.37 GHz) limits the lowest output frequency to 284 kHz (= 2.37 GHz / VCO_DIV / CLKout_DIV, where VCO_DIV=8 (max) and CLKout_DIV=1045 (max) ).
    Alan
    Report Abuse
    • Reply
  • anthony Stewart
    Posted by anthony Stewart
    on May 08 2012 13:51 PM
    Prodigy110 points
    Hi Tom,
    The LMK should work but might be overkill for a 300KHz quadrature clock. Like Timothy said the 7414 can produce the complementary outputs easily.
    Now for the quadrature phases, I would use the standard positive feedback CMOS oscillator which has 1 inverter,  and  3 RC phase shifters with a buffer in a loop.
    Hartley oscillator for example with 90 phase shifter>
    Tony Stewart
    EE since 1975  It's just a simple application of Ohm's Law  . ..  Former employee of Bristol Aerospace, Interdiscom, Burroughs/Unisys, Iris Systems, C-MAC ....
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
