• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Clocks & Timers » Clocks & Timers Forum » CDC7005 - 160 MHz generation
Share
Clocks & Timers
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Newton
Posted by Newton
on Apr 26 2012 14:04 PM
Expert1105 points
Can you  generate 160mhtz out of 240mhtz, using CDC7005  and if so how?
CDC7005
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Leandro_z
    Posted by Leandro_z
    on Apr 26 2012 14:40 PM
    Expert3725 points
    Hi Ayn,
    could you please specify if the 160MHz is applied to the REF_IN pin or to the VCXO pins?
    The max REF_IN frquency is 130MHz,while the max VCXO frequency is 800MHz.
    thanks and best regards
    Leandro
    Report Abuse
    • Reply
  • Newton
    Posted by Newton
    on May 07 2012 12:41 PM
    Expert1105 points
    160 MHz is applied to  VCXO pin.  As you mentioned REF_IN does not have that capability.
    From the Data Sheet:
    The programmable predividers M and N give a high flexibility to the frequency ratio of the reference clock to VCXO: VCXO_IN/REF_IN = (NxP)/M.
     So, how do we set up these M, N, and P. I don’t see that anywhere in datasheet but I assume generating 160 MHz out of 240 MHz should be possible using these parameters.
    Report Abuse
    • Reply
  • Leandro_z
    Posted by Leandro_z
    on May 08 2012 10:43 AM
    Expert3725 points
    Hi Ayn,
    I need to know what is your REF_IN as well. In any case if you use a 160MHz at VCXO pin, you can only have at the output either the same frequency (160M) or a submultiple of it. The division ratios for the CDC7005 are 2,4,8,16.
    Leandro
    Report Abuse
    • Reply
  • Newton
    Posted by Newton
    on May 08 2012 17:33 PM
    Expert1105 points
    Leandro,
    It is 240 MHz.
    How do we generate 160 MHz our of this?
    What you mentioned tells me that it is impossible since these are only integer dividers that cannot generate 160 MHz that we need.
    Datasheet says that the programmable predividers M, N, and P can be set to get VCXO_IN/REF_IN = (NxP)/M. How do we set up these M, N, and P. I don’t see that anywhere in datasheet but I assume generating 160 MHz out of 240 MHz should be possible using these parameters.
    regards
    Report Abuse
    • Reply
  • Leandro_z
    Posted by Leandro_z
    on May 09 2012 05:50 AM
    Expert3725 points
    Hi Ayn,
    the CDC7005 cannot handle 240MHz at the REF_IN pin. Do you have the chance to use rather a 120MHz signal at PRI_REF?
    If this is the case, You need to set P=1, N=4 and M=3 in order to get 160MHz outputs.
    If this is not the case, do you have any other clock frequency below than 180MHz (this is the max REF_IN frequency, I wrote a typo in some previous post) on your board
    Leandro
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
