• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Clocks & Timers » Clocks & Timers Forum » CDCM7005BGA-EVM
Share
Clocks & Timers
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
CDCM7005BGA-EVM
CDCM7005BGA-EVM
This question is answered
Stephen Taranovich
Posted by Stephen Taranovich
on Mar 29 2010 15:45 PM
Intellectual1330 points
Cusotmer needs engineering support for his CDCM7005BGA-EVM. Customer states: According to Quick Start model 2-1 of the User’s Guide, The VCXO provided on the Eval PCB outputs 491.52MHz; as suggested we input 61.44MHz @ PRI_REF. In this configuration with power applied D1, D2, and D3 are illuminated and we observe an ≈61.44MHz signal @ Y0A/B which appears to be phase locked to the reference.
I do not know if this output is actually being produced by the CDCM7005 or if it is simply the reference being passed through unaltered. After observing what appears to be valid quick start performance; attempted to control output freq. via the SPI software package downloaded from the TI site. Whenever the send button on the software is clicked the all output from the eval board ceases, and D1-D3 are off. Any configuration of the GUI we have attempted appears to have this effect, including default settings. The RESET button also appears to have no impact. Pushing the PWR DWN button resets the board to the Quick Start condition described above. But any subsequent attempt to manipulate the hardware via the SPI software produces the same result. Phase noise measurements taken in quick start were not what we expected but we assume that this is because quick start is not actually a true indication of part performance.
At this point we assume that these issues are setup related on our end: either due to software considerations such as version, compatibility, operator error, etc, or actual hardware setup, such as jumper settings.
Please provide any amplifying information you feel is applicable, perhaps a loadable setup for the SPI software would be valuable, or screenshots of setups/measurements. Additionally any information regarding expected phase
CDCM7005BGA-EVM
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Justo
    Posted by Justo
    on Mar 30 2010 04:44 AM
    Verified Answer
    Verified by Justo
    Intellectual1600 points
    Hi Stephen,
     The input in PRI-REF is not connected to the output. What the customer sees is the VCXO divided by 8, 491.52M / 8 = 61.44MHz. The signal is coming from the VCXO. For a better understanding of the internal clocks please look at page 3 of the CDCM7005 datasheet.
     Regarding the EVM and the configuration, the default settings of the CDCM7005 are in pages 22-25 of the datasheet. For the default settings and 61.44MHz input the CDCM7005 should be locked (D1 is ON). That means that the inputs to the PFD (Phase Frequency Detector) need to be aligned.
    For the EVM and using the default configuration:
    Frequency from PRI_REF coming to PFD: 61.44M / 128 = 480kHz
    Frequency from VCXO into the PFD: 491.52M / 8 / 128 = 480kHz
     If the customer wants to verify that the CDCM7005 EVM works correctly, he/she can change OUT_MUX_0 = 6, then the output frequency of Y) should be 491.52M / 6 = 81.92MHz.
     Finally, find attached the software used to control the CDCM7005 EVM just to be in the same page.
    JL
    CDCM7005 EVM
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
