• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Clocks & Timers » Clocks & Timers Forum » Reprogramming PLL when it provides CPU clock
Share
Clocks & Timers
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Eric Walker
Posted by Eric Walker
on May 26 2010 13:50 PM
Prodigy150 points
I have a CDCE706 that provides the core clock frequency to the processor. Can I reprogram the PLL chip to provide a new frequency to the processor without causing glitches, etc that would cause undesired behavior (assuming, I program it correctly)?
cdce706
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • mapefer3
    Posted by mapefer3
    on May 28 2010 10:30 AM
    Verified Answer
    Verified by mapefer3
    Expert5745 points
    The CDCE706 allows changing programmatically the output frequency via I2C, but to change from Frequency1 to Frequency2 avoiding intermediate frequencies or glitches, is not as straight forward as using the CDCE925, CDCE937, CDCE949, CDCE913.
    If in order to change from Frequency1 to Frequency2 only one PLL parameter (N or M) needs to change. For example, if in high speed mode with a clock input of 25MHz, changing from 300MHz to 180MHz can be done with different N, M PLL configurations. If choosing for 300MHz a setup of N=12 and M=1 and then to program the CDCE706 to 180MHz with (N=72 and M=10), as N or M are not sharing the same register address, one of them would be updated first, therefore if I chose writing first M=10, I will get an intermediate frequency of 30MHz, before I write N=72 getting the final 180MHz. That is not a concern for the CDCE925, CDCE913, CDCE937, CDCE949) where there is a bit that selects the PLL settings active, therefore the PLL setting inactive can be written and once that is completed use that bit to activate it. More details are included in the Application Note:  http://focus.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=scaa105&fileType=pdf
    Changing from 300MHz to 180MHz can be done without intermediate frequencies or glitches looking by taking into account to only change one PLL parameter (N or M) to go from frequency1 to frequency 2. If the PLL parameters for 300MHz are chosen to be (M=10 and N=120), then programming the PLL to M=10 and N=72, only implies N to change and therefore a smooth change in terms of period and duty cycle as can be seen in the plot below can be seen, in a lock time of 25.7us.
    In the plots below, note that the the pink graph is the frequency, the yellow is the period and the blue is the duty cycle of Y0 when reprogrammed to go from PLL settings 1 to PLL settings 2, in order as explained above.
    The lock time for the CDCE706 and CDCE906 varies with the delta of the change but the worst case for each of the increases of decreases is as follows:
                         -in high speed mode when going from 180MHz to 300MHz is 3.5us.
                         -in normal mode when going from 200MHz to 80MHz is 40us
                         -in normal mode when going from 80MHz to 200MHz is 9.3us
    If changing the frequency without caring about intermediate frequencies I would recommend using the CDCE925, CDCE913, CDCE949 or CDCE937, they are the same type of device with some added functionality, please note that the core supply for them is 1.8V, although the output stage can be powered also a 3.3V and 2.5V, therefore they support also a 3.3V or 2.5 LVCMOS too.
    CDCE913 cdce706 CDCE925 CDCE937 CDCE906 CDCE949
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
