Hi I have a board with an LMK04826 that is used with a 100MHz VCXO to provide a 125MHz clock to an Ethernet PHY.
When cold at -40C the LMK04826 loses lock and I start to see Ethernet instability.
Thinking the issue relates to a reset for the LMK04826 I investigated the connections of the reset pin.
I found that the pin is driven low by VHDL in an FPGA so it will be low when the FPGA is configured.
Looking at the LMK04826 datasheet I could not find any definative data stating how long the reset should be active for.
Anyone any ideas? Thought of investigation paths?
Regards Derek
