• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Clocks & Timers » Clocks & Timers Forum » BQ32000 reading issues
Share
Clocks & Timers
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
benjamin navarro
Posted by benjamin navarro
on Oct 14 2010 12:16 PM
Prodigy200 points
Hi everybody! I'm trying to use a BQ32000 with a microcontroller and there is a strange problem...
I can write to any register and read the seconds or minutes register without any problem but when I read an other register, I get the value of this one, and then I can't do anything, the I2C connexion seems like closed. I can't "talk" with the RTC or the TMP101 which is on the same bus (and works perfectly before that), the µC holds on, waiting for an incoming data. I use exactly the same functions for reading and writing for all the registers if we except the value of the pointer register of course. Does anyone have an idea to solve this problem?
Just a precision, I use a 5v/3.3v level converter which seems to works fine.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Brad Lambert
    Posted by Brad Lambert
    on Oct 15 2010 18:23 PM
    Prodigy440 points
    Benjamin,
    Please supply additional details on the level shifter you are using.  It is possible for I2C to get stuck if the level shifters are not implemented correctly.  This happens when the slave device is transmitting a low and fails to receive the correct number of SCL edges.
    A similar problem can occur with asynchronous battery backup switchovers.  Basically, if the RTC goes into backup mode while driving the I2C bus low it prevents the bus from returning to normal once main power is restored.  The action to correct this is listed below:
    1. Drive the bus with START condition
    2. Hi-Z the Master SDA output
    3. Generate 9 SCL periods
    4. Enable the Master SDA output
    5. Drive the bus with a STOP condition
    Do you know if the microcontroller is driving a NACK after the last data read byte?  The last data read byte should be followed by a NACK and a STOP.
    Brad
    Report Abuse
    • Reply
  • benjamin navarro
    on Oct 16 2010 02:37 AM
    Prodigy200 points
    Thank you so much! The problem was the ACK I send instead of a NACK! However on the datasheet (figure 5, page 9) it says that a ACK must be send before a STOP and not a NACK. It is normal or it is a mistake? If it's a mistake, it should be corrected to avoid problems like mine. Thank you again for your help!
    Benjamin
    Report Abuse
    • Reply
  • Brad Lambert
    on Oct 19 2010 15:15 PM
    Prodigy440 points
    Benjamin,
    Glad to help.  I have submitted a request for the data sheet to be updated.
    Brad
    Report Abuse
    • Reply
  • Tushar Kulkarni
    Posted by Tushar Kulkarni
    on Jan 17 2011 23:38 PM
    Prodigy245 points
    Hi Benjamin,
    I am writing code in C for BQ32000, but not able to establish contact with BQ32000,
    If possible will you help me with code you written for BQ32000.
    I am using LM3S9B96 with internal I2C with pullup of 4.7k Ohm.
    Report Abuse
    • Reply
  • benjamin navarro
    on Jan 18 2011 04:12 AM
    Prodigy200 points
    My code is for PIC µcontrollers and for the HI-TECH C Compiler but I think that it could help you. There is the header code :
    #ifndef BQ32000_H_
    #define BQ32000_H_
    #define XTAL_FREQ 32MHZ
    #include "i2c/i2c.h"
    #include "delay.h"
    #include "lcd.h"
    #include <stdio.h>
    #include <string.h>
    //adresses
    #define BQ_ADRW     0b11010000
    #define BQ_ADRR     0b11010001
    //Registres
    #define SEC_REG     0
    #define MIN_REG     1
    #define HOURS_REG     2
    #define DAY_REG     3
    #define DATE_REG     4
    #define MONTH_REG     5
    #define YEAR_REG     6
    #define CAL_REG     7
    #define TCH2_REG     8
    #define CFG2         9
    //Jours de la semaine (DAY_REG)
    #define DIMANCHE     1
    #define LUNDI         2
    #define MARDI         3
    #define MERCREDI     4
    #define JEUDI        5
    #define VENDREDI     6
    #define SAMEDI         7
    void BQInit();
    char getReg(char reg);
    void setReg(char reg, char data);
    void setSeconds(char);
    void setMinutes(char);
    void setHours(char);
    void setDay(char);
    void setDate(char);
    void setMonth(char);
    void setYear(char);
    void getSeconds(char*);
    void getMinutes(char*);
    void getHours(char*);
    void getDay(char*);
    void getDate(char*);
    void getMonth(char*);
    void getYear(char*);
    int dayToInt(char* day);
    void intToDay(int d, char* jour);
    #endif /*BQ32000_H_*/
    and here the source code, if there is any problem, ask me
    #include "BQ32000.h"
    void BQInit() {
        OpenI2C(MASTER, SLEW_ON);
        SSPADD=19;  //clock = FOSC/(4 * (SSPADD + 1))
        setSeconds(128);
        setSeconds(0);
        setMinutes(0);
        setHours(12);
        setDay(LUNDI);
        setDate(1);
        setMonth(1);
        setYear(10);
    char getReg(char reg) {
        char data;
            IdleI2C();
        StartI2C();
            IdleI2C();
        WriteI2C(BQ_ADRW);
            IdleI2C();
        WriteI2C(reg);
            IdleI2C();
        StartI2C();
            IdleI2C();
        WriteI2C(BQ_ADRR);
        data=ReadI2C();
            NotAckI2C();
            IdleI2C();
        StopI2C();
        DelayUs(60); //temps minimum avant de re gŽrŽrer un Start
        return data;
    void setReg(char reg, char data) {
            IdleI2C();
        StartI2C();
            IdleI2C();
        WriteI2C(BQ_ADRW);
            IdleI2C();
        WriteI2C(reg);
            IdleI2C();
        WriteI2C(data);
            IdleI2C();
        StopI2C();
    void getSeconds(char* sec) {
        char data = getReg(SEC_REG);
        *sec = (((data&112)>>4)*10+(data&15));
    void getMinutes(char* min) {
        char data = getReg(MIN_REG);
        *min = (((data&112)>>4)*10+(data&15));
    void getHours(char* hours) {
        char data = getReg(HOURS_REG);
        *hours = (((data&48)>>4)*10+(data&15));
    void getDay(char* jour) {
        switch(getReg(DAY_REG) & 0x07) {
            case LUNDI:
                sprintf(jour ,"%s" ,"Lun");
            break;
            case MARDI:
                sprintf(jour ,"%s" ,"Mar");
            break;
            case MERCREDI:
                sprintf(jour ,"%s" ,"Mer");
            break;
            case JEUDI:
                sprintf(jour ,"%s" ,"Jeu");
            break;
            case VENDREDI:
                sprintf(jour ,"%s" ,"Ven");
            break;
            case SAMEDI:
                sprintf(jour ,"%s" ,"Sam");
            break;
            case DIMANCHE:
                sprintf(jour ,"%s" ,"Dim");
            break;
    void getDate(char* date) {
        char data = getReg(DATE_REG);
        *date = (((data&48)>>4)*10+(data&15));
    void getMonth(char* month) {
        char data = getReg(MONTH_REG);
        *month = (((data&16)>>4)*10+(data&15));
    void getYear(char* year) {
        char data = getReg(YEAR_REG);
        *year = (((data&240)>>4)*10+(data&15));
    void setSeconds(char sec) {
        char data;
        getSeconds(&data);
        data &= 0x80;
        sec = ((sec/10)<<4)+sec-((sec/10)*10);
        setReg(SEC_REG, sec|data);
    void setMinutes(char min) {
        char data;
        getMinutes(&data);
        data &= 0x80;
        min = ((min/10)<<4)+min-((min/10)*10);
        setReg(MIN_REG, min|data);
    void setHours(char hours) {
        char data;
        getHours(&data);
        data &= 0xC0;
        hours = ((hours/10)<<4)+hours-((hours/10)*10);
        setReg(HOURS_REG, hours|data);
    void setDay(char day) {
        setReg(DAY_REG, day);
    void setDate(char date) {
        date = ((date/10)<<4)+date-((date/10)*10);
        setReg(DATE_REG, date);
    void setMonth(char month) {
        month = ((month/10)<<4)+month-((month/10)*10);
        setReg(MONTH_REG, month);
    void setYear(char year) {
        year = ((year/10)<<4)+year-((year/10)*10);
        setReg(YEAR_REG, year);
    int dayToInt(char* day) {
        if(!strcmp(day,"Dim")) return 1;
        else if(!strcmp(day,"Lun")) return 2;
        else if(!strcmp(day,"Mar")) return 3;
        else if(!strcmp(day,"Mer")) return 4;
        else if(!strcmp(day,"Jeu")) return 5;
        else if(!strcmp(day,"Ven")) return 6;
        else if(!strcmp(day,"Sam")) return 7;
        return -1;
    void intToDay(int d, char* jour) {
        switch(d) {
                case LUNDI:
                break;
                case MARDI:
                break;
                case MERCREDI:
                break;
                case JEUDI:
                break;
                case VENDREDI:
                break;
                case SAMEDI:
                break;
                case DIMANCHE:
                break;
    Report Abuse
    • Reply
  • Tushar Kulkarni
    on Feb 02 2011 06:00 AM
    Prodigy245 points
    Hi Benjamin
    Thank you very much.
    I apply code your, writing and reading to resisters is fine, but RTC is not updating time.
    It contunusly shows value which is set by program not gating update.
    Plz help if possible.
    Report Abuse
    • Reply
  • Tushar Kulkarni
    on Feb 24 2011 04:19 AM
    Prodigy245 points
    Hi Benjamin
    Will you please give some more information about steps below.
    data=ReadI2C();
            NotAckI2C();
    Report Abuse
    • Reply
  • benjamin navarro
    on Feb 24 2011 05:22 AM
    Prodigy200 points
    Just before these instructions, I ask to the BQ32000 to give me the value of a register so I store this value into "data" and then I send a Not Acknowledge to confirm to the BQ3200 that I have receive the information correctly
    Report Abuse
    • Reply
  • Tushar Kulkarni
    on Feb 25 2011 01:27 AM
    Prodigy245 points
    Hi Benjamin,
    BQ32000 is giving BCD output. Can I directly store in "char" or have to do some process?
    Please help.
    Report Abuse
    • Reply
  • benjamin navarro
    on Feb 25 2011 02:11 AM
    Prodigy200 points
    That's why I wrote the getSeconds, getMinutes, etc functions. They return the value of the register in a decimal number, not in BCD. If you want to convert them into strings you can use the sprintf function like this :
    char h,m,s,aString[12];       // char type does not mean that you store characters into it, only that the data is on one byte (value≤255)
    getHours(&h);
    getMinutes(&m);
    getSeconds(&s);
    sprintf(aString,"%2dh %2dm %2ds",h,m,s); // aString will contain something like "08h 36m 54s"
    note : Only the getDay function gives you a string directly
    Report Abuse
    • Reply
  • Tushar Kulkarni
    on Feb 27 2011 22:26 PM
    Prodigy245 points
    Hi Bejamin,
    Thank you for great help,
    My code is working now.
    Thank you again......
    Report Abuse
    • Reply
  • benjamin navarro
    on Feb 28 2011 02:46 AM
    Prodigy200 points
    you're welcome
    Report Abuse
    • Reply
  • Varun P
    Posted by Varun P
    on Mar 05 2011 03:08 AM
    Prodigy60 points
    hi Benjamin,
    Where have you got that  header file of i2c, could you please put it up here on the forum,
    it would be of great help to me.
    Varun
    PS: because the one that I have is for firmware controlled master mode.
    Report Abuse
    • Reply
  • benjamin navarro
    on Mar 05 2011 04:31 AM
    Prodigy200 points
    I've got all the I2C relative files from my compiler (Hi-Tech PICC18). I put you all of them in a zip file in attachment
    5140.I2C.zip
    Report Abuse
    • Reply
  • Varun P
    Posted by Varun P
    on Mar 06 2011 23:44 PM
    Prodigy60 points
    Thank you Benjamin,
    Varun
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
