Hi all
Would you mind if we ask CDCM6208?
The customer will use Output0 and 1.
So, we would like to know the termination of unused outputs and power rail.
<Power rail>
They should tie unused VDDO pins to ground thru 1kohm resistor.
Is this correct?
<Output>
We assume that it depends on output type CML, HCSL, LVCMOS, LVDS and LVPECL.
HCSL, CML, LVDS and LVPECL : It should terminate the unused outputs with 100 resistor across the differential pins?
LVCMOS : Open?
If you have some advice, could you let us know?
Kind regards,
Hirotaka Matsumoto
