AFE5809EVM: AFE5809GUI configuration
Intellectual 710 points
Part Number: AFE5809EVM
I want to save all the values that I edit in AFE5809GUI to AFE5809 chip, so everytime I powerup a device it loads my last saved values (SPI logic for each block of AFE) instead of default '0'.
Is there a document that can help me to understand GUI ?  I couldn't found this info in datasheet or maybe I missed it, Can someone please help me.
Thanks.
  • Hi Vatsal,
    There is no way to power up the device with the last saved values.
    However you could use the Recording feature provided in the GUI to save a sequence of commands and loads the commands from the saved file after starting the GUI for the next time.
    Here is the procedure to follow:
    1. Start the GUI
    2. Click on 'Software Reset' button to issue a reset and load the EVM default values
    3. Click on 'Record Commands' button
    4. Configure the AFE.
    5. Click on 'Save Commands' button. This will open up a dialog box to save the file. Choose the folder and save the file as an *.cfg file.
    6. Restart the GUI.
    7. Click on 'Software Reset' button
    8. Load the previously saved configuration file by clicking on 'Exec CMD file' button.
    Praveen
    TI makes no warranties and assumes no liability for applications assistance or customer product design. You are fully responsible for all design decisions and engineering with regard to your products, including decisions relating to application of TI products. By providing technical information, TI does not intend to offer or provide engineering services or advice concerning your designs.
  • In reply to Praveen Aroul:
    Hi Praveen,
    ok, What about the register's / profile ram values?
    So, It says it doesn't have default values, Once I configure my AFE chip using GUI all values in register will be same after power off?
