hi ti,
I want to read the 16 channel of ads7953.
I have tried the sequence as given in datasheet but it didn't worked.
please provide the read sequence for the same.
thanks
roushan
hi ti,
thanks
roushan
Hello
Unfortunately there is no sample code.
I would suggest starting off with manual reads, this will help to confirm that digital communications and timing are correct.
Using an oscilloscope probing the digital lines, will help give a visual check and make it easier to debug be comparing what the digital lines are expected to do vs what they are doing. This usually is an easier approach to debugging.
Once communication and timing are all correct, you can move on to using Auto 1 or auto 2 modes to sequence through channels.
regards
Cynthia
