  • TI Thinks Resolved
CCS/TSW1400EVM: MMwave studio does not run, matlab engine could not be started
Prodigy 120 points
Part Number: TSW1400EVM
For running my hsdc pro for tsw1400evm (awr1642) , i have installed my mmwave studio and matlab runtime v8.5.1 as told in the user guide but when i run the mmwave studio i shows that matlab engine could not start and cannot be initialised .
Can i know what i have to do to solve this ,, Do i have to install any other matlab softwares other than the run time software . I f should can pls provide the link and the version number ..
Thank you
  • Hi Jopaul,
    I've asked an expert to look into this and we should have an answer for you in the next few days.
    Cheers,
    Akash
  • HI, Jopaul:
    Are you using the newest radar studio 2.1.0.0?
    http://software-dl.ti.com/ra-processors/esd/MMWAVE-STUDIO/latest/index_FDS.html
    In users guide section 2.1, it provides a link to the 32 bit matlab runtime v8.5.1.  Can you make sure you are using that?
    C:\ti\mmwave_studio_02_01_00_00\docs\mmwave_studio_user_guide.pdf
    Zigang
  • In reply to zigang Yang:
    It is been several days, please let me know whether you are able to solve your problem.
    Zigang
    Sorry for the late reply , but yes im using the latest version 2.01 of mmwave studio wave . Can u let me know if there is any jumper connections that i have to in the TSW1400 or AWR1642 to solve the spi connectivity issue.
    Thank you
  • In reply to jopaul jince:
    HI,
    The MATLAB run-time engine should be able to run without hardware connected.  So it is not a jumper issue. Can you double check whether you have a 32 bit run-time engine or 64 bit run-time engine?  Can you follow the link in the document to install the run-time engine?
    Zigang
    Bro the matlab problem is successfully solved right now , but now when i run the mmwave studio i cannot get spi connectivity. Although i have loaded bss and mss , and even after I press spi connect button it shows disconnected in red for spi.
    HI,
    Now it is a good time to check the switch settings.  Please refer to the following thread.
    https://e2e.ti.com/support/sensors/f/1023/t/846620
    Zigang
    BTW, how were you able to solve the MATLAB ISSUE?
    Zigang
    I downloaded the 32 bit version of matlab for the computer , this seemed to sovle the problem..
    But How to sovle the spi connectivity issues...
