Other Parts Discussed in Thread: DAC7760, ADS8688
I posted a schematic several months ago and implemented the feedback I received. However, the design is still causing issues. I have combed through the data sheet and other examples and cannot find the problem.
Currently the with inputs floated, the read back on SPI is always high and when I meter the front end of the input channels (in front of and behind the filter), there is a strange 2.005V signal that appears. The chip is laid out on a PCB following the guidelines spelled out in the datasheet.
My code has been tested using the ADS8668EVM and functions perfectly using only the 4 SPI signals (so it is most likely not a software issue).
Is there something I'm overlooking?
Any help would be appreciated.
Thanks!
