I am using ADS7953 with VA = +3.3V, VBD = +2.5V. Datasheet states: "The analog supply is always greater than or equal to the digital supply.". This same question is asked couple of times here but I am still confused with given different answers.:
http://e2e.ti.com/support/data-converters/f/73/t/865233?ADS7953-Power-up-sequence --> TI says no need for power up sequencing.
https://e2e.ti.com/support/data-converters/f/73/t/498035?Power-up-requirements-of-ADS7953-for-analog-and-digital-supplies --> TI says VA should be powered before or at the same time.
https://e2e.ti.com/support/data-converters/f/73/t/839210?ADS7953-Timing-sequence --> TI says it's better to turn VA ON first, otherwise chip can act abnormally.
https://e2e.ti.com/support/data-converters/f/73/t/476201?ADS7954-Power-on-sequence --> TI says ideally VA and VBD are ramped together but VA is always greater.
My question is:
- I turn +2.5V for VBD ON first, VA is at 0V. Then, after 5ms delay the +3.3V VA turns ON and settles. After 1 second I start communication through SPI. Would I have any problem? Do I have to sequence power on to make sure VA>VBD always or not?
Kind regards,
Zeki
