Part Number: THS5671EVM
I'm hoping to use the THS5671A to convert from an FPGA output to custom analog input board, but we are using single supply (+5V) for all our components. The DAC datasheet says it is specified for 5V analog supply as well as +/-5V, but the eval module appears to need the dual supply. Is it possible to run the eval module from a single 5V supply? If so, what would be the correct way to supply the board's power? I have a reference 2.5V supply for our op amps available as well.
