• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » look for TUSB3200 demo
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
zhao fangpeng
Posted by zhao fangpeng
on Aug 24 2011 06:14 AM
Prodigy10 points
Hi,everyone.
I am working sound card with TUSB3200,but the TUSB3200 firmware dev kit doesn't seem to include the demo.
So I need a demo ,and a bootloader.
can someone help me?thanks a lot.
demo bootloader tusb3200
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Frank Minich
    Posted by Frank Minich
    on Aug 24 2011 07:17 AM
    Verified Answer
    Verified by Don Dapkus
    Expert4110 points
    Zhao,
    The TUSB3200 Firmware Development Kit has sample applications for both the 'EVM1' (which has an AC'97 codec) and the 'EVM2' (which has an I2S codec).
    You have to install, then unzip a couple of times, but they are there.
    Frank
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 24 2011 07:34 AM
    Intellectual290 points
    The TUSB3200 Firmware Development Kit is a firmware installer, how to use?
    Thank you!
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 24 2011 07:53 AM
    Installation is complete The TUSB3200 Firmware Development Kit, no prompt, then how to use? Thank you!
    Report Abuse
    • Reply
  • Frank Minich
    on Aug 24 2011 08:04 AM
    Expert4110 points
    Powder,
    As part of the installation, if you selected 'custom', you were shown where the installer intended to place the FDK, and you had an opportunity to change the location.
    I think the default is c:\Program Files (x86)\My Company Name\My Product Name
    Frank
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 24 2011 08:17 AM
    Thanks! Finally see the code! Here also ask: how to download the code to tusb3200, what tools?
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 24 2011 08:28 AM
    Compiled using keil c51, prompted to download to e2rom, regardless of tusb3200, can it?
    Report Abuse
    • Reply
  • Frank Minich
    on Aug 24 2011 08:35 AM
    Expert4110 points
    Powder,
    After the Keil tools build the image, there's some postprocessing by some tools in the FDK to convert to binary and add the EEPROM header that the TUSB3200A expects to see.  Then you blow that combined image into a I2C EEPROM, which the TUSB3200A reads as it boots.
    I use the MIIC-204 from www.mcc-us.com to download to the EEPROM, using their 'iBurner' application.
    Frank
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 24 2011 08:51 AM
    Frank Minich
    Oh. As long as you are talking about compiled in accordance with good after the first download to e2rom, before this can not connect tusb3200?
    Very, very grateful
    Report Abuse
    • Reply
  • Frank Minich
    on Aug 24 2011 09:03 AM
    Expert4110 points
    Powder,
    I'm not sure I understand your question.
    If the TUSB3200A boots and does not find an external EEPROM, it does have some internal ROM program that allows it to connect to the USB, but that functionality has never been checked-out nor documented, and it certainly does not support audio.  The intent always has been that the TUSB3200A loads its application from the EEPROM; with no EEPROM the 3200 basically does not function.
    Frank
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 24 2011 09:24 AM
    Frank Minich
    Separately compiled program can burn directly to e2rom, and then welded to the tusb3200 the pcb board. Or e2rom itself first in the tusb3200 the pcb board, through the computer usb bus and tusb3200 guide download e2rom? tusb3200 Boot Loader have been inside it?
    Thank you advice!
    Report Abuse
    • Reply
  • Frank Minich
    on Aug 24 2011 09:30 AM
    Expert4110 points
    The answer is in section 2.2.2 of the TUSB3200A Data Manual:  only the first of your two options.
    The TAS1020B supports both of your options, but the TUSB3200A does not.
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 24 2011 09:36 AM
    Frank Minich
    thank you very much!
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 25 2011 23:09 PM
    Hello  Frank Minich
    This TUSB3200_boot.exe running, flash, no prompt for the name and output name. How to use? Thank you!
    Report Abuse
    • Reply
  • Frank Minich
    on Aug 26 2011 07:40 AM
    Expert4110 points
    Powder,
    Load the project for either EVM into the Keil uVision3 tool, and look under the project->options 'user' tab.
    I may be looking at a 'doctored' version, but basically it invokes:
    hex2bin.exe <name of output file produced by Keil> temp.bin I 1 (that's the upper-case letter 'i' followed by space followed by the number '1')
    stcboot.exe temp.bin <name of the binary file you will use to program the eeprom>
    Report Abuse
    • Reply
  • powder du
    Posted by powder du
    on Aug 26 2011 11:23 AM
    Thanks! Frank Minich
    Directly set is generated in keil "REV929.bin" and "TEMP.bin" two documents, that is the eeprom?
    Report Abuse
    • Reply
123
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
