• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » TAS3204 noise
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    How to determine the power at output of modulator from DAC back-off level
    Posted 1 day ago
    by Habeeb Ur Rahman Mohammed
    Customers often ask how they can determine the power at the output...
    DAC Essentials: What’s with all this glitch-ing?
    Posted 5 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 7 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
TAS3204 noise
TAS3204 noise
This question is answered
Thomas Deuble
Posted by Thomas Deuble
on Oct 24 2011 02:58 AM
Intellectual520 points
We are using the TAS3204 together with a TAS5611 and we get a audible noiselevel over the speakers.
If I connect the inputs of the TAS5611 to ground it is quiet.
If I measure the output of the TAS3204 when it is steaming audio from the inputs to the outputs and its inputs pulled to VMID I get about -50 dB of noise.
Anything wrong with the TAS3204?
Thanks for any answer.
Thomas
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Oct 27 2011 06:56 AM
    Guru106115 points
    Hi, Thomas,
    The TAS3204 is supported by another team. I am going to move your post to the Audio Forum where they will see it.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • susan xu
    Posted by susan xu
    on Oct 27 2011 08:49 AM
    Verified Answer
    Verified by Don Dapkus
    Expert3030 points
    Thomas,
    As far as I know, TAS3204 doesn't have a noise issue that serious.  Are you using the analog I/O on TAS 3204?   Could that be some noise coming from power supply?  I am not familiar with HW, do you have an EVM from us?  Have you tested that on our EVM?
    Susan
    Report Abuse
    • Reply
  • Christopher K.
    Posted by Christopher K.
    on Nov 04 2011 11:16 AM
    Intellectual430 points
    My self build TAS3204 PCB has a high noise level on the DAC Outputs too and I can't figure out why. What I have done so far.
    Supplying the Analog- and Digital-Frontend with seperate Voltagereferences. No improvement.
    Short Circuit of the Analog Inputs, so the TAS measures a diffential Zero. No improvement.
    Streaming the digital Input to the DAC section with no signal present (digital 0). No improvement.
    So for me it seems, like the DAC itself is generating the noise, since the Input Signals and Voltages are all clean.
    My PPS Program is as simple as it could be. Only the Init and Framwork Block for the TAS4302 are present and the ADC is linked one on one to the DAC.
    Maybe you Thomas could check on a similar basis if you DAC is also generating the noise independently from the source settings, than we would be facing the same problem.
    Yours faithfully,
    Christopher
    Report Abuse
    • Reply
  • Thomas Deuble
    on Nov 04 2011 11:48 AM
    Yes Christopher
    the input was shorted to Vmid and the TAS3204 was streaming from the input to the output.
    What amp are you using to listen to the noise?
    Thomas
    Report Abuse
    • Reply
  • Christopher K.
    on Nov 04 2011 12:04 PM
    Hi Thomas,
    I plan to have a TAS5630 behind the DSP but up to now, I don't need it. The noise can be clearly seen with an Oscilloscope. Are you useing the EVM Board or is your PCB a selfbuild version too? Unfortunately I don't have a EVM Board, so I have no clue if the Eval Board is making the same noise, which I doubt. I'am really lost in this case. I tried most of the poor documented registers but the noise stayes the same. The audio volume also has no impact on the noiselevel . The Hardware seems fine, all Voltages are nominal in the ranges they are supposed to. The Quarz is working stable and still there is this noise problem.
    Report Abuse
    • Reply
  • Christopher K.
    on Nov 07 2011 13:07 PM
    Hey Thomas,
    I think I got a clue to solve my problem. When I took a closer look at the TAS3204EVM Module Users Guide, which can be found online on the TI Page, it seems that the Op-Amp at the analog outputs is configured as LP-Filter. You can see the symetrical setup of the output Op-Amp in a picture, together with some caps. This would mean, that the DAC is supposed to have noise on it, and you need to filter the output of the TAS. Unfortunately I don't have a EVM Board, so I can't make measurments on it. Maybe TI or a person with a EVM Board could help us here with simple test. The AOut testpoints are in front of the supposed LP-Filter opamp. This would mean, that you can see the noise at the testpoints, but it should be filtered out at the analog outputs.
    Yours faithfully,
    Christopher
    Report Abuse
    • Reply
  • Thomas Deuble
    on Nov 08 2011 02:07 AM
    Hey Christopher,
    maybe your on the right way.
    Did you check the x-over frequence of the LP filter?
    What frequencys are dominant in the noisepattern that you measure?
    Thomas
    Report Abuse
    • Reply
  • Christopher K.
    on Nov 09 2011 00:28 AM
    Hello Thomas, Since I don't have a EVM Board or the schematics for it I can't say if the EVM Board has a Post-LP-Filter or with witch frequency it is working. I just made an educated guess based on a picture of the EVM Module. I would expect something lika a sallen-key structure for a possible Post-LP-Filter. What I can tell you, is that the noise I have measured had a main frequency somewhere arround 730 kHz. What would be pretty easy to Filter out. So if you Thomas do have an EVM Module could you make the measurements if have mentioned above? Best regards, Christopher
    Report Abuse
    • Reply
  • Christopher K.
    on Jan 04 2012 02:50 AM
    Hello again,
    I now had some time to think a little bit more about the noise problem of the TAS3204. With an additional Lowpass-Filter behind the DAC I was able to reduce the noise too an almost not anymore hearable amount. Now I have to figure out, how to filter out the rest of the noise. What I don`t understand is why something so important as a needed post LP-Filter is not described in the data sheet. There is not even a hint that a additional filter may be needed. But since this solution is working while every thing else failes it seems to be the only way to get rid of the noise of the TAS3204 analog outputs.
    So please TI give me some specifications for the post LP-Filter you are using on your TAS3204 EVM Boards, so I can create a noise free DSP Board.
    Yours faithfully,
    Christopher
    Report Abuse
    • Reply
  • susan xu
    Posted by susan xu
    on Jan 04 2012 09:24 AM
    Expert3030 points
    In this post,
    http://e2e.ti.com/support/applications/audio/f/22/t/98583.aspx
    you got the schematic of our EVM board, would that help at all?
    Susan
    Report Abuse
    • Reply
  • Christopher K.
    on Jan 04 2012 15:47 PM
    Hello Susan,
    You're right I do have the schematics for the EVM Board. There you can find the post low pass filter in form of a MFB Filter Type with an additional analog type filter in front. Unfortunaltely these MFB Filters are hard to calculate and the additional analog filter doesn't make this task easier. Since I would like to have a different filter type with an additional signal amplification integrated it would realy help if I know what kind of signal exactly must be filtered out. So if you would be so kind and try to look up these informations for me?
    Yours faithfully,
    Christopher
    Report Abuse
    • Reply
  • susan xu
    Posted by susan xu
    on Jan 06 2012 09:33 AM
    Expert3030 points
    Christopher,
    I asked the HW engineer who designed the board, this is what he told me:
    The cut off frequency I use is ~29-32 kHz to keep the audio band flat 10Hz-22 kHz.
    Hope this helps.
    Susan
    Report Abuse
    • Reply
  • Christopher K.
    on Jan 09 2012 12:11 PM
    Hello Susan,
    thank you for your efforts. The values are in the range that I would have expected for the lp filter. I will try to figure out how to eleminate the rest of the noise I got on the outputs. Still a definition for the noise pattern on the DACs would be nice.
    Yours faithfully,
    Christopher
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
