• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » PCM5100 output filter
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 7 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is answered
Peter Mix
Posted by Peter Mix
on Dec 31 2011 02:15 AM
Prodigy170 points
In the datasheet for the PCM5100, the recommended output filter is a 470 ohm resistor and a 2.2nF (.0022uF) cap.  This has an approximate -3dB filter point of 153 kHz.  However, the datasheet for the PCM510xEVM-U eval board uses 100 ohms and a 22 nF (.022 uF) cap.  That combo has a -3dB point of about 72 kHz.  Why the discrepancy?
PeterM
PCM5100 output filter i2s
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Dec 31 2011 17:40 PM
    Guru101915 points
    Hi, Peter,
    Because different people write the d/s versus design the EVM.
    Thanks for pointing that out. We will try to fix them to be consistent.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Peter Mix
    Posted by Peter Mix
    on Jan 11 2012 01:54 AM
    Prodigy170 points
    So which is the actual preferred filter?
    PeterM
    Report Abuse
    • Reply
  • Don Dapkus
    on Jan 25 2012 22:26 PM
    Verified Answer
    Verified by Peter Mix
    Guru101915 points
    Hi, Peter,
    Sorry for the delay. I'd go with what's on the EVM as we have thoroughly tested that combination.
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • B. Bowling
    Posted by B. Bowling
    on Aug 03 2012 06:12 AM
    Prodigy175 points
    I have a follow-on question to this thread - what type of output stage does the PCM5100 have - is it a push-pull, class A, etc? Its not specified in the datasheet anywhere I can find.
    Thanks - Bruce
    Report Abuse
    • Reply
  • Akio Ito
    Posted by Akio Ito
    on Aug 05 2012 21:02 PM
    Prodigy10 points
    TI has recommended fc=54kHz as 2nd order LPF in the PCM DAC datasheets.
    Why fc=54kHz? I think as follows.
    The frequency response of N-order Butterworth LPF is;
    1/sqrt((f/fc)^(2*N)+1)
    N=2, 20kHz, fc=54kHz
    -10*log10((20/54)^4+1) =-0.081 dB
    For the response at 20kHz within -0.1dB,
    fc =f/(10^(2*0.1/20)-1)^(2*N))
    =20000/(10^(2*0.1/20)-1)^4)
    =51.195 kHz
    In case of 1st order LPF,
    fc =20000/(10^(2*0.1/20)-1)^2)
    =131.04 kHz
    In case of the value of PCM5100 datasheet,
    N=1, 20kHz, fc=153kHz
    -10*log10((20/153)^2+1) =-0.074 dB
    The value of datasheets may be designed to keep the frequency response within 0.1dB.
    Report Abuse
    • Reply
  • B. Bowling
    on Aug 23 2012 15:20 PM
    Prodigy175 points
    I am still looking for an answer to this - what type of electrical output stage does the PCM5100 have?
    Thanks - Bruce
    Report Abuse
    • Reply
  • Don Dapkus
    on Aug 23 2012 21:54 PM
    Guru101915 points
    Hi, Bruce,
    Sorry we missed your post. Let me check tomorrow and get back to you.
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Don Dapkus
    on Aug 24 2012 07:38 AM
    Verified Answer
    Verified by Don Dapkus
    Guru101915 points
    Hi, Bruce,
    It's push-pull.
    I'm curious -- why is this information needed? How does it help you in your design or comparison to a competitor's part? I'm kind of new to the codec world; in fact, my boss like to tease me and call me an AmpHead.
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Ramgopal Divakar
    Posted by Ramgopal Divakar
    on Aug 24 2012 08:34 AM
    Prodigy10 points
    Hi!
    I had asked Bruce to find me the answer. So can I drive it directly to an op amp inverting amplifier adjust gains for increasing or lowering volume? I am not familiar with PWM (class D) circuits and wanted to make sure this isn't that.
    Divakar
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
