• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » DIX4192 - how to control DIR-to-DIT frame offset?
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 3 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 4 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 10 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Wabri
Posted by Wabri
on Jan 12 2012 05:39 AM
Prodigy35 points
AES11 specifies an "output timing phase" requirement for AES3 signals:
5.3.1.1 - The difference between the timing-reference points of the digital audio synchronizing signal and all output signals, at the equipment connector points, shall be less than ± 5% (or ± 18 deg) of the AES3-frame period.
The AES term "frame" means "one LRCK cycle" in DIX4192 datasheet lingo.
As far as I understand, the DIX4192 DIT module has a clock input only, but no frame sync (LRCK) input. This means that the DIT is freely runing, without any determined framing relationship to neither the DIR, nor to any of the audio serial ports.
While looking for a solution, I've spotted the DIT module's BLS i/o and SYNC out pins (Fig. 11). What I need to end up with, is a SYNC signal with no more than ± 5% offset (with DIR input port as a reference). As far as I understand, BLS is for firing a new block preamble only, not for re-aligning the transmitter's SYNC frame.
What's the trick for tweaking the DIX4192 to adhere to the AES3/AES11 standards? - Thanks.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Patrick Galvin
    Posted by Patrick Galvin
    on Jan 23 2012 10:16 AM
    Verified Answer
    Verified by Don Dapkus
    Genius16290 points
    Wabri,
    The DIX4192 does support AES data.  For the serial audio ports, input data is then sent to an AES encoder before being sent out by the DIT.  Likewise for the DIR, input data is sent to DIR buffers before being sent to DIT buffers (in accordance with AES standards) before being sent out.  So no tweaks should be necessary to achieve AES output.
    Patrick Galvin
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
