• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » DIT4192 with simultaneous optical and coax outputs?
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 12 hours ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 1 day ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 7 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Andy Peters
Posted by Andy Peters
on Mar 22 2012 23:21 PM
Intellectual670 points
Howdy, all --
The data sheet doesn't exactly answer this question. Is it possible for the DIT4192 or DIT4096 to drive both a TOTX-type fiber transmitter and a coax through the usual  transformer at the same time? Or is it best to put a gate or a bus switch between the transmitter and the two types of outputs?
Thanks!
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Mar 24 2012 07:49 AM
    Guru101325 points
    Hi, Andy,
    We usually switch between these, but let me have someone look into your question.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Patrick Galvin
    Posted by Patrick Galvin
    on Mar 26 2012 15:24 PM
    Genius16290 points
    Andy,
    The PCM1808 EVM User's Guide (pg 16) has an example of both outputs being used: http://www.ti.com/lit/ug/sleu078/sleu078.pdf .
    Patrick Galvin
    Report Abuse
    • Reply
  • Andy Peters
    on Mar 26 2012 15:50 PM
    Verified Answer
    Verified by Don Dapkus
    Patrick Galvin
    Andy,
    Oh, I see.. the coax output is taken at TX- and if you look at the transformer schematic, you notice that it inverts the signal polarity. The dotted pin goes to ground and the undotted side of that coil goes to TX-. I notice that the data sheet for the DIT4096 connects both TX+ and TX- to the transformer, and as such signal swing across it requires the 2:1 transformer to attenuate at the output. I assume that the output is basically a high-current complementary pair and using one of the outputs only isn't a problem (otherwise the TOTX driver wouldn't work).
    If only TI would choose parts for eval platforms where one can get a data sheet in English! The only data sheet for the DA-02 is in Japanese. It would be nice to know whether it's a 2:1 or 1:1 or whatever transformer. Oh, well, the eval is several years old.
    -a
    Report Abuse
    • Reply
  • Don Dapkus
    on Mar 29 2012 07:54 AM
    Guru101325 points
    Andy,
    Sorry about the transformer. This EVM was actually designed by the Burr-Brown guys in Japan, hence why they used Japanese components! :-)
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Andy Peters
    on Mar 29 2012 13:18 PM
    Don Dapkus
    Andy,
    -d2
    If it was designed by the Burr-Brown guys in Tucson, I could drive over to them by the airport on my lunch hour.
    Oh, wait ...
    Anyways, seriously, is an English data sheet available? I know I can use a Scientific Conversion or whatever part as a replacement, but it helps to know the turns ratio ...
    Thanks!
    -a
    Report Abuse
    • Reply
  • Don Dapkus
    on Apr 04 2012 23:38 PM
    Guru101325 points
    Andy,
    Too many people knew where the old BB plant was in Tucson. We had to relocate them all to an undisclosed location... Even myself have never been to this new site... I think it might be buried underground in the desert...
    Why don't you just use the Scientific Conversion one like show in fig 13, but flip the polarity. The guy who runs Scientific Conversion is a hoot! If you've got a free hour or two, give him a call, and he'll talk you ear off about transformers...
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Andy Peters
    on Apr 05 2012 11:33 AM
    Don Dapkus
    Andy,
    It's actually pretty sad, driving by the old BB plant. Oh, well. I hope the staff are happy in their underground bunker! Summer's coming. Being underground isn't so bad.
    Using a Scientific Conversion part is my plan. I'm just not sure which one to choose. The "usual" configuration is to use the TX+ and TX- lines to drive the transformer primary differentially, and in the "use both optical and coax" design, the transformer primary is driven single ended. My assumption is that with the differential drive, you need to attenuate in the transformer to keep the coax amplitude within S/PDIF spec (a volt, I think). In single-ended drive mode, you don't (?) need the attenuation. So maybe it's the 1:1 transformer in the single-ended mode. What's the worst that could happen!
    I'm going to get samples of the SC parts. The footprints for 2:1 and 1:! parts are the same, so for first article builds, it's easy enough to swap them out.
    -a
    Report Abuse
    • Reply
  • Don Dapkus
    on Apr 05 2012 21:22 PM
    Guru101325 points
    Call the dude. He will set you straight. He knows this stuff in and out!
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Andy Peters
    on Apr 09 2012 13:36 PM
    Don Dapkus is on vacation until 4/16
    Will do! I just have to clear out a block of time ...
    -A
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
