• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » TLV320AIC3100 LP no valid playback on 3.0.x kernel
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
Kuzemko Aleksander
Posted by Kuzemko Aleksander
on Mar 26 2012 23:47 PM
Intellectual515 points
mplayer 01\ -\ Zbojn������cka.mp3
Creating config file: /root/.mplayer/config
MPlayer SVN-r33094-4.5.3 (C) 2000-2011 MPlayer Team
Playing 01 - Zbojn.
Audio only file format detected.
Clip info:
Title: Zbojnicka
Artist: Lunatic Gods
Album: Vlnobytie
Year: 2012
Comment:
Track: 1
Genre: Metal
Load subtitles in ./
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 44100 Hz, 2 ch, s16le, 320.0 kbit/22.68% (ratio: 40000->176400)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
================================================== ==<============4> tlv320aic3100 LP: asoc: tlv320aic3100 LP no valid playback
<1>Unable to handle kernel NULL pointer dereference at virtual address 00000058
<1>pgd = ec69c000
<1>[00000058] *pgd=ac6cf831, *pte=00000000, *ppte=00000000
<0>Internal error: Oops: 17 [#1] PREEMPT SMP
 <d>Modules linked in:Modules linked in: wl12xx_sdio wl12xx_sdio wl12xx wl12xx
CPU: 1 Not tainted (3.0.21-01313-g859a880-dirty #163)
  PC is at omap_abe_dai_startup+0x1c/0x144
  LR is at omap_abe_dai_startup+0x1c/0x144
  pc : [<c03d21a4>] lr : [<c03d21a4>] psr: a0000013
sp : ebe73c38 ip : ebe73c38 fp : ebe73c5c
 r10: c073e3d0 r9 : ec46d400 r8 : c073d710
r7 : ebdd8400 r6 : ec46d400 r5 : ec468c00 r4 : ec490000
  r3 : ecc96360 r2 : 00000000 r1 : ec468c00 r0 : 00000000
  Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
  Control: 10c5387d Table: ac69c04a DAC: 00000015
  Backtrace: Backtrace:
[<c03d2188>] (omap_abe_dai_startup+0x0/0x144) from [<c03c2384>] (soc_pcm_open+0x9c/0x5a4)
[<c03c22e8>] (soc_pcm_open+0x0/0x5a4) from [<c03ca114>] (soc_dsp_fe_dai_open+0xac/0x3a0)
[<c03ca068>] (soc_dsp_fe_dai_open+0x0/0x3a0) from [<c03b1238>] (snd_pcm_open_substream+0x70/0xb0)
[<c03b11c8>] (snd_pcm_open_substream+0x0/0xb0) from [<c03b13b8>] (snd_pcm_open+0x140/0x258)
r5:ec4d24e0 r5:ec4d24e0 r4:ecd89960 r4:ecd89960
[<c03b1278>] (snd_pcm_open+0x0/0x258) from [<c03b155c>] (snd_pcm_playback_open+0x44/0x48)
[<c03b1518>] (snd_pcm_playback_open+0x0/0x48) from [<c03a3418>] (snd_open+0x144/0x2c0)
r5:ecd89960 r5:ecd89960 r4:c059ab60 r4:c059ab60
[<c03a32d4>] (snd_open+0x0/0x2c0) from [<c01209fc>] (chrdev_open+0x12c/0x1e4)
[<c01208d0>] (chrdev_open+0x0/0x1e4) from [<c011b6c8>] (__dentry_open+0x188/0x2c8)
r7:ebefbd08 r7:ebefbd08 r6:ecc0cbe0 r6:ecc0cbe0 r5:ec963aa0 r5:ec963aa0 r4:ecd89960 r4:ecd89960
[<c011b540>] (__dentry_open+0x0/0x2c8) from [<c011b8e8>] (nameidata_to_filp+0x68/0x70)
[<c011b880>] (nameidata_to_filp+0x0/0x70) from [<c012a0f8>] (do_last+0xc8/0x6d4)
r7:00000026 r7:00000026 r6:00000000 r6:00000000 r5:00080802 r5:00080802 r4:ebe73ed0 r4:ebe73ed0
[<c012a030>] (do_last+0x0/0x6d4) from [<c012b73c>] (path_openat+0xc4/0x3c0)
[<c012b678>] (path_openat+0x0/0x3c0) from [<c012bb30>] (do_filp_open+0x38/0x8c)
[<c012baf8>] (do_filp_open+0x0/0x8c) from [<c011b454>] (do_sys_open+0xe8/0x17c)
r8:00000001 r8:00000001 r7:ffffff9c r7:ffffff9c r6:00000005 r6:00000005 r5:00080802 r5:00080802 r4:ebcf6000 r4:ebcf6000
[<c011b36c>] (do_sys_open+0x0/0x17c) from [<c011b520>] (sys_open+0x24/0x28)
[<c011b4fc>] (sys_open+0x0/0x28) from [<c004df00>] (ret_fast_syscall+0x0/0x30)
<0>Code: e1a06000 e5910008 e1a05001 ebfcacb2 (e5901058)
<4>---[ end trace 857471665bae8791 ]---
Segmentation fault
Kernel 3.0.21. (p-android-omap). SOC tlv320aic3100. Source you can see in https://github.com/fat-tire/kernel3NookTablet
tlv320AIC3100 OMAP4430
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • navada
    Posted by navada
    on Mar 28 2012 05:05 AM
    Prodigy445 points
      Use the following amixer commands before issuing a playback
    amixer cset name="DL1 Media Playback Volume" 120
    amixer cset name="SDT DL Volume" 120
    amixer cset name="DL1 MM_EXT Switch" 1
    amixer cset name="Sidetone Mixer Playback" 1
    amixer cset name="DL1 Mixer Multimedia" 1
    Mukund
    Report Abuse
    • Reply
  • Kuzemko Aleksander
    on Mar 28 2012 08:12 AM
    localhost ~ # amixer cset name="DL1 Media Playback Volume" 120
    numid=7,iface=MIXER,name='DL1 Media Playback Volume'
    ; type=INTEGER,access=rw---R--,values=1,min=0,max=149,step=0
    : values=120
    | dBscale-min=-120.00dB,step=1.00dB,mute=1
    localhost ~ # amixer cset name="SDT DL Volume" 120
    numid=24,iface=MIXER,name='SDT DL Volume'
    : values=120
    localhost ~ # amixer cset name="DL1 MM_EXT Switch" 1
    numid=33,iface=MIXER,name='DL1 MM_EXT Switch'
    ; type=BOOLEAN,access=rw------,values=1
    : values=on
    localhost ~ # amixer cset name="Sidetone Mixer Playback" 1
    numid=37,iface=MIXER,name='Sidetone Mixer Playback'
    : values=on
    localhost ~ # amixer cset name="DL1 Mixer Multimedia" 1
    numid=52,iface=MIXER,name='DL1 Mixer Multimedia'
    : values=on
    localhost ~ # aplay
    After this command I receive:
    omap_abe_dai_startup start
    pgd = ec614000
    [00000058] *pgd=acd8a831, *pte=00000000, *ppte=00000000
    Modules linked in:
    CPU: 1 Not tainted (3.0.21+ #174)
    PC is at omap_abe_dai_startup+0x28/0x19c
    LR is at omap_abe_dai_startup+0x28/0x19c
    pc : [<c03ab900>] lr : [<c03ab900>] psr: a0000013
    sp : ec24dc38 ip : ec24dc38 fp : ec24dc5c
    r10: c0726238 r9 : ecdfa500 r8 : c0725578
    r7 : ec676000 r6 : ecdfa500 r5 : ecdfe240 r4 : ec468000
    r3 : ecc96360 r2 : 00000000 r1 : 00000001 r0 : 00000000
    Control: 10c5387d Table: ac61404a DAC: 00000015
    Backtrace:
    [<c03ab8d8>] (omap_abe_dai_startup+0x0/0x19c) from [<c039bad4>] (soc_pcm_open+0x9c/0x5a4)
    [<c039ba38>] (soc_pcm_open+0x0/0x5a4) from [<c03a3864>] (soc_dsp_fe_dai_open+0xac/0x3a0)
    [<c03a37b8>] (soc_dsp_fe_dai_open+0x0/0x3a0) from [<c038a980>] (snd_pcm_open_substream+0x70/0xb0)
    [<c038a910>] (snd_pcm_open_substream+0x0/0xb0) from [<c038ab00>] (snd_pcm_open+0x140/0x258)
    r5:ec4662e0 r4:ec66c320
    [<c038a9c0>] (snd_pcm_open+0x0/0x258) from [<c038aca4>] (snd_pcm_playback_open+0x44/0x48)
    [<c038ac60>] (snd_pcm_playback_open+0x0/0x48) from [<c037cb60>] (snd_open+0x144/0x2c0)
    r5:ec66c320 r4:c0573fe8
    [<c037ca1c>] (snd_open+0x0/0x2c0) from [<c0121280>] (chrdev_open+0x12c/0x1e4)
    [<c0121154>] (chrdev_open+0x0/0x1e4) from [<c011bf4c>] (__dentry_open+0x188/0x2c8)
    r7:ec233750 r6:ec632460 r5:ec95bb28 r4:ec66c320
    [<c011bdc4>] (__dentry_open+0x0/0x2c8) from [<c011c16c>] (nameidata_to_filp+0x68/0x70)
    [<c011c104>] (nameidata_to_filp+0x0/0x70) from [<c012a97c>] (do_last+0xc8/0x6d4)
    r7:00000026 r6:00000000 r5:00080802 r4:ec24ded0
    [<c012a8b4>] (do_last+0x0/0x6d4) from [<c012bfc0>] (path_openat+0xc4/0x3c0)
    [<c012befc>] (path_openat+0x0/0x3c0) from [<c012c3b4>] (do_filp_open+0x38/0x8c)
    [<c012c37c>] (do_filp_open+0x0/0x8c) from [<c011bcd8>] (do_sys_open+0xe8/0x17c)
    r8:00000001 r7:ffffff9c r6:00000004 r5:00080802 r4:ec07a000
    [<c011bbf0>] (do_sys_open+0x0/0x17c) from [<c011bda4>] (sys_open+0x24/0x28)
    [<c011bd80>] (sys_open+0x0/0x28) from [<c004df00>] (ret_fast_syscall+0x0/0x30)
    Code: e34c006a eb065f7b e5950008 ebfcacad (e5902058)
    ---[ end trace d44132d07d3b888e ]---
    Report Abuse
    • Reply
  • navada
    Posted by navada
    on Apr 02 2012 04:00 AM
    Prodigy445 points
      Looks like you are using an old version of the codec driver.
    You can request for the latest TLV320AIC3100 driver corresponding to kernel 3.0 at
    http://www.ti.com/tool/codecdrivers-sw
    Mukund
    Report Abuse
    • Reply
  • Igor Yo
    Posted by Igor Yo
    on Apr 02 2012 11:25 AM
    Prodigy60 points
    Hi, we're also looking for the driver but there are no TLV320AIC3100 drivers for OMAP4xxx or 3.x kernels withing the Audio Codec Selection Tool (http://www.ti.com/tool/codecdrivers-sw) and codecdrivers-sw@list.ti.com is not replying.
    audio codecs Driver Audio TLV320AIC3100 OMAP4 3.x kernel
    Report Abuse
    • Reply
    on Apr 03 2012 11:06 AM
    I get drivers.
    But I have a problem. There is no fm/fm34.h in package.
    This files included in sound/soc/omap/omap4_panda_aic31xx.c.
    Report Abuse
    • Reply
  • navada
    Posted by navada
    on Apr 03 2012 23:50 PM
    Prodigy445 points
      You can safely remove the include file. If there are any dependencies those can also be removed.
    Mukund
    Report Abuse
    • Reply
    on Apr 08 2012 13:07 PM
    <3> tlv320aic3100 Media1 LP: no BE found for PDM_DL2
    <4> tlv320aic3100 Media1 LP: asoc: tlv320aic3100 Media1 LP no valid playback route from source to sink
    <3> tlv320aic3100 Media1 LP: dsp: no backend DAIs enabled for tlv320aic3100 Media1 LP
    My full dmesg
    http://pastebin.com/jTPebsrt
    Report Abuse
    • Reply
    on Apr 09 2012 10:40 AM
    Can anybody say, how to debug this problem?
    1|root@android:/d/asoc # cd OMAP4_ACCLAIM-ABE/tlv320aic3100\ Media1\ LP/
    root@android:/d/asoc/OMAP4_ACCLAIM-ABE/tlv320aic3100 Media1 LP # ls
    state
     cat state
    [tlv320aic3100 Media1 LP - Playback]
    State: close
    Backends:
    No active DSP links
    cd /d/asoc/
    root@android:/d/asoc # ls
    OMAP4_ACCLAIM-ABE
    codecs
    dais
    platforms
    1|root@android:/d/asoc # cat codecs
    null-codec
    null-codec
    null-codec
    tlv320aic3100-codec
    root@android:/d/asoc # cat dais
    null-codec-dai
    null-codec-dai
    null-codec-dai
    MultiMedia1 LP
    MODEM
    Vibra
    Tones
    Voice
    MultiMedia2
    MultiMedia1
    omap-mcbsp-dai.3
    omap-mcbsp-dai.2
    omap-mcbsp-dai.1
    omap-mcbsp-dai.0
    tlv320aic3100-MM_EXT
    root@android:/d/asoc # cat platforms
    aess
    omap-pcm-audio
    snd-soc-dummy
    Report Abuse
    • Reply
  • navada
    Posted by navada
    on Apr 09 2012 23:27 PM
    Prodigy445 points
     Sounds like the ABE back-end and front-end are not mapped. The following commands maps the Media LP to MM_EXT resulting in data flow inside ABE.
    Mukund
    Report Abuse
    • Reply
    on Apr 10 2012 09:58 AM
    Thank you Mukund, but where to get amixer for ICS?
    Report Abuse
    • Reply
    on Apr 13 2012 00:22 AM
    I also see many error on the logcat
    I/TabletStatusBar( 234): DISABLE_EXPAND: yes
    E/AudioFlinger( 105): createTrack_l() Bad parameter: sampleRate 44100 format 1, channelMask 0x00000001 "for output 0x19fff20 with format 1
    E/AudioTrack( 169): AudioFlinger could not create track, status: -22
    E/SoundPool( 169): Error creating AudioTrack
    D/ShutdownThread( 169): Notifying thread to start shutdown longPressBehavior=1
    Report Abuse
    • Reply
    on Apr 15 2012 23:43 PM
    I have such output for aplay -L
    root@android:/mnt/sdcard # aplay -L
    null
    Discard all samples (playback) or generate zero samples (capture)
    default:CARD=OMAP4ACCLAIMABE
    OMAP4_ACCLAIM-ABE,
    Default Audio Device
    root@android:/mnt/sdcard # aplay -l
    **** List of PLAYBACK Hardware Devices ****
    card 0: OMAP4ACCLAIMABE [OMAP4_ACCLAIM-ABE], device 0: Multimedia null-codec-dai-0 []
    Subdevices: 1/1
    Subdevice #0: subdevice #0
    card 0: OMAP4ACCLAIMABE [OMAP4_ACCLAIM-ABE], device 1: Multimedia null-codec-dai-1 []
    Subdevices: 1/1
    card 0: OMAP4ACCLAIMABE [OMAP4_ACCLAIM-ABE], device 3: Multimedia tlv320aic3110-MM_EXT-3 []
    Subdevices: 1/1
    card 0: OMAP4ACCLAIMABE [OMAP4_ACCLAIM-ABE], device 4: FM Playback tlv320aic3110-MM_EXT-4 []
    Subdevices: 1/1
    card 0: OMAP4ACCLAIMABE [OMAP4_ACCLAIM-ABE], device 5: FM Capture tlv320aic3110-MM_EXT-5 []
    Subdevices: 1/1
    Is it correct? I also have
    <3> tlv320aic3110 Media1 LP: no BE found for PDM_DL2
    <4> tlv320aic3110 Media1 LP: asoc: tlv320aic3110 Media1 LP no valid playback route from source to sink
    <3> tlv320aic3110 Media1 LP: dsp: no backend DAIs enabled for tlv320aic3110 Media1 LP
    and no sound.
    Report Abuse
    • Reply
    on Apr 16 2012 06:34 AM
    Now I have sound only when I run such commands
    1. Start Music player from ICS.
    2.No sound
    3. Run
    ABE CODEC CONTROLS
    ./tinymix 71 1
    ./tinymix 130 127
    ./tinymix 64 150
    ./tinymix 76 1
    ./tinymix 77 1
    ./tinymix 139 1
    ./tinymix 137 1
    ./tinymix 129 127
    ./tinymix 70 1
    ./tinymix 132 2
    ./tinymix 136 2
    ./tinymix 73 152
    ./tinymix 74 50
    ABE PLAYBACK MIXERS
    ./tinymix 51 1
    ./tinymix 36 1
    ./tinymix 23 120
    ./tinymix 6 118
    ./tinymix 32 1
    ./tinymix 3 1
    ./tinymix 9 10
    ./tinymix 21 120
    ./tinymix 20 120
    ABE RECORDING MIXERS
    ./tinymix 55 9
    ./tinymix 54 10
    ./tinymix 27 120
    ./tinymix 18 100
    ./tinymix 43 1
    ./tinymix 22 100
    ./tinymix 35 1
    4. Now I have sound on ICS
    5. When I close Music player, and run it again I have no sound.
    Any idea / help?
    Report Abuse
    • Reply
    on Jun 07 2012 12:03 PM
    What is a reason of such error
    tlv320aic3110 Media1 LP: no BE found for PDM_DL2 ?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
