• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » SRC4190
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
SRC4190
SRC4190
This question is answered
hideyuki sakai
Posted by hideyuki sakai
on Apr 16 2012 05:16 AM
Intellectual515 points
I need your help.
1. My customer want to use under "slave mode" for SRC4190.
  SDIN(Pin #4) : Input / BCKI(Pin #5) : Input / LRCKI(Pin #6) : Input
  SDOUT(Pin #23) : Output / LRCKO(Pin #24) : Input / BCKO(Pin #25) : Input
  "TABLE 1" on page 16, data sheet shows 2 setting for slave mode.
  Which, "000" or "100),  is suitable for above slave mode setting?
2. RCKI(Pin #2) will not be needed for slave mode usage(no input).
 I am wondering Pull-up to Vcc or Pull-down to GND will be better for RCKI, no use input pin?
H. Sakai
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Apr 22 2012 09:04 AM
    Guru101625 points
    Hi, Sakai-san,
    Sorry we missed your post last week. We will check it out ASAP.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Patrick Galvin
    Posted by Patrick Galvin
    on Apr 22 2012 23:33 PM
    Genius16290 points
    Sakai-san,
    1)  Either of these settings is suitable for slave mode.
    2)  A GND pull-down would be recommended.
    Patrick Galvin
    Report Abuse
    • Reply
  • hideyuki sakai
    on Apr 23 2012 02:17 AM
    Dear, Patrick-san.
    Thank you  for your reply.
    One Japanese engineer mentioned that RCKI should be input even if slave mode.
    I am confusing which is correct.
    Could you please double-confirm whether RCKI input is not needed under slave mode
    or not. Sorry, again.
    H.Sakai
    Report Abuse
    • Reply
  • Patrick Galvin
    on Apr 23 2012 14:59 PM
    Genius16290 points
    Sakai-san,
    The RCKI should be needed as a reference source for the SRC.  For parts like SRC4392, MCLK or RXCKI can be chosen as a reference but the SRC4190 only has the RCKI.
    Patrick Galvin
    Report Abuse
    • Reply
  • hideyuki sakai
    on Apr 23 2012 21:07 PM
    Dear, Patrick-san.
    I understand RCKI is needed as reference source.
    I am having several questions about RCKI under slave mode.
    Please teach me.
    1. Should RCKI synchronous any other external signal?  Asynchronous is OK?
    2. If asunchronous is OK, How about the spec of RCKI input? For instance, frequency, etc.
    3. in the case of our application, RCKI will be interrupted or unstable at TV channel change.
    Can SRC4190 work correctly under such RCKI condition? What is happened inside of SRC4190?
    4. How to solve above malfunction if there was a problem? RESET is needed?
    5. How log will be needed from RESET force to RESET release(chip active)?
    H.Sakai
    Report Abuse
    • Reply
  • Patrick Galvin
    on Apr 25 2012 15:56 PM
    Verified Answer
    Verified by Don Dapkus
    Genius16290 points
    Sakai-san,
    1)  RXCKI must be a multiple of fs, (128, 256, 512) but does not need to be synchronous.
    2)  RXCKI min frequency is 128xfs, and max is 50MHz, per page 4 of the datasheet.  If it is an external source, a low jitter source is recommended as well.
    3)  The SRC4190 will not work without the reference clock.
    4)  Re-applying the reference clock should be all that is needed.
    5)  An active RXCKI must be provided, and RST must be asserted for a minimum of 500nS to force a reset (per page 16 of the datasheet).
    Patrick Galvin
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
