• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » using the Noise Gate function from AIC3105 codec
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    DAC Essentials: What’s with all this glitch-ing?
    Posted 4 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 6 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
    Engineering the world through Analog
    Posted 11 days ago
    by Hagop Kozanian
    Our lives are surrounded by analog everywhere we go. That’s...
This question is answered
Alexander Sorg
Posted by Alexander Sorg
on May 03 2012 07:11 AM
Prodigy120 points
in our custom board we are getting some background noise when we record audio. I checked the recorded wav file using Audicity and the noise is easy to identify during the silence periods. Using the noise removal effect from Audicity I was able to clean that noise with a couple of mouse clicks. As far as I know, Audicity use a noise gating function to achieve that.
So, I connected the AIC3105EVM to my PC and use the headset of it as input  to the Line1's EVM. I played the noisy wav file, just to "simulate" the effect of our custom board. Using the  AIC3105EVM Evaluation Tool I tried to setup the codec in order to use the built-in noise gate, but after changing the setting in the AGC tab (Threshold, Hystesis, AGC settings, etc), I couldn't make any substancial improvenment, it even get worse in the most of the cases.
I am not really sure what I am doing wrong, so I hope that someone may enlighten me to find the correct way to configure the noise gate of the codec to get the same/similar result as in Audicity.
Thanks in advance.
Alex
Active Noise Cancellation 320adc3101 audio codec ADC resolution
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Converter Apps
    Posted by Converter Apps
    on May 03 2012 13:33 PM
    Mastermind18925 points
    Hi Alex,
    Here is an app note that goes over the AGC function on this family of products:
    http://www.ti.com/lit/an/slaa260/slaa260.pdf
    Report Abuse
    • Reply
  • Alexander Sorg
    on May 03 2012 15:30 PM
    Prodigy120 points
    thanks for your reply. Yes, I know already that app note and I already tried with the values suggested in the examples there, without success. Should the noise gate of the AIC3105 work in a similar way as the one in the Audicity plug-in? I moved the threshold through all the possible levels, varying also the max. AGC gain and I did not get any noise reduction.Or Am I missing anything? I am not sure if the noise gate needs a special setup (i.e other components like the PGA gain) that I am not  aware of...
    thanks in advance.
    Alexander
    Report Abuse
    • Reply
  • Converter Apps
    on May 03 2012 16:11 PM
    If you can send your register settings, I can take a look at what you are doing. If you are using the GUI, you can go to the Command Line Interface Tab and copy and paste to a text file. The noise gate should work pretty much as it would in audicity. The ADC's need to be powered up since the feedback is digital from the ADC. Aside from that I would have to review your settings.
    Report Abuse
    • Reply
  • Alexander Sorg
    on May 04 2012 05:57 AM
    Prodigy120 points
    Report Abuse
    • Reply
  • Alexander Sorg
    on May 04 2012 06:04 AM
    Prodigy120 points
    I tried to post a picture of our HW setup in the last post together with other files but somehow the post is empty (I think I missed the "insert". So I will try again.
    Thanks in advance for your help.
    Alex
    6330.AIC3105.log
    Click here to play this audio clip
    Report Abuse
    • Reply
  • Alexander Sorg
    on May 07 2012 06:38 AM
    Prodigy120 points
    just to extend a little bit my last post, i do the following EVM SW setup:
    1) in Audio Input/ADC tab:
    - After connecting the PC-EVM via USB, I start the EVM software tool and execute e software reset.
    - Unmute (active) Line1R/Line1R "L ADC" and "R ADC" options.
    - Left and Right ADC power up.
    2) In High Power Outputs tab
    - set the HPL Output to i.e 4.
    - set PGA_L and PGA_R to i.e. -15.5
    -activate Power up.
    3) Play audio in PC
    4) In In AGC tab
    - start to modify all the settings in different ways. No positive results whatever I change.
    Hope that it helps to find what I could be doing wrong.
    Thanks in advance.
    Alex
    Report Abuse
    • Reply
  • Alexander Sorg
    on May 07 2012 15:46 PM
    Prodigy120 points
    any advice?
    Thanks.
    Alex
    Report Abuse
    • Reply
  • Hans-Juergen Ruhsam
    Posted by Hans-Juergen Ruhsam
    on May 14 2012 04:22 AM
    Verified Answer
    Verified by Converter Apps
    Expert5645 points
    the case is taken offline.
    Best regards
    Hans
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
