• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » TAS1020B Sample Rate and MCLK
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    How to determine the power at output of modulator from DAC back-off level
    Posted 16 hours ago
    by Habeeb Ur Rahman Mohammed
    Customers often ask how they can determine the power at the output...
    DAC Essentials: What’s with all this glitch-ing?
    Posted 4 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 7 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
This question has suggested answer(s)
Alex Yin
Posted by Alex Yin
on May 25 2012 17:19 PM
Prodigy170 points
From TAS1020B data manual, the USB sample rate clock (CSCLK) and master clock output (MCLKO) are tied with each other. Is there a way to separate them?
For example, for 32-bits stereo 48kHz audio data, CSCLK will be 32*2*48000 = 3.072MHz, and I also want MCLKO to be 19.2MHz or 9.6MHz, is it possible?
If the answer is yes, how to do it? If the answer is no, what is the alternative solution?
Alex
TAS1020B CSCLK MCLKO
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Frank Minich
    Posted by Frank Minich
    on May 29 2012 07:45 AM
    Suggested Answer
    Expert4110 points
    Alex,
    No, as per Figure 2-1 in the data manual.
    > Is it possible?
    Since there's no small integer 'M' such that 19.2/M = 3.072, it's not possible synchronously.  Could you use ACG1/CSCLK for the 3.072MHz output and ACG2/MCLK02 for the 19.2MHz output, since you apparently don't need the two signals to be synchronous?
    Frank
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on May 29 2012 14:09 PM
    Prodigy170 points
    Frank,
    Can you elaborate on the part of "using ACG1/CSCLK for the 3.072MHz output and ACG2/MCLK02 for the 19.2MHz output"? Yes, I don't need the two signals to be synchronous, but isn't only one can be used for I2S streaming data? How to use both ACG1 and ACG2 for the same I2S streaming?
    Alex
    Report Abuse
    • Reply
  • Frank Minich
    on May 29 2012 14:29 PM
    Expert4110 points
    Alex,
    In all cases I've seen, the MCLK to the codec has to be some multiple of Fs, and in particular, MCLK has to be an integer multiple of BCLK.  For 48kHz, the BCLK is 3.072MHz as you indicate, and MCLK is typically 8 x BCLK, or 24.576MHz.  The codecs that I've seen seem to do OK with this.
    You indicate that you need to produce something like 19.2MHz or 9.6MHz or something similar - so your codec must not need MCLK and BCLK to be related like I've seen (i.e., by a frequency divider).  I don't understand what you're saying, but I assume that you know what you're doing.
    You can let the ACG1 produce MCLK at 24.576MHz, dividing down to a BCLK of 3.072MHz - but you don't have to use that MCLK at your codec.  You can use ACG2 to develop a different MCLK02 that is 19.2MHz or 9.6MHz.
    Perhaps you could share your intent as to the I2S codec you intend to use - maybe that would help clarify your purpose.
    Frank
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on May 29 2012 15:35 PM
    Prodigy170 points
    Frank,
    The I2S codec has only one requirement: the MCLK is 19.2MHz or 9.6MHz.
    The other requirement is for CSCLK to be either 3.072MHz or 1.536MHz.
    How to exactly set up the ACGs to get the above setup? From the data manual, it says if using ACG2, then both CSCLK and codec MCLK will be sourced from ACG2?
    Alex
    Report Abuse
    • Reply
  • Frank Minich
    on May 30 2012 07:30 AM
    Expert4110 points
    Please see the TAS1020B Data Manual http://www.ti.com/lit/ds/symlink/tas1020b.pdf.
    In particular, see Figure 2-1.  Setup Frequency Synthesizer 1 to develop your 3.072MHz CSCLK, and Frequency Synthesizer 2 to develop your 19.2MHz MCLKO2.  Don't connect MCLKO to your codec - use MCLKO2 instead.
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on May 30 2012 14:23 PM
    Prodigy170 points
    If using synthesizer 1 for CSCLK and synthesizer 2 for MCLKO2, and connect MCLKO2 to codec clock, will it require asynchronous streaming? The USB device descriptor needs to be modified for asynchronous transfer? How about SoftPll(), is there any change required for this kind of usage?
    Report Abuse
    • Reply
  • Frank Minich
    on May 30 2012 15:16 PM
    Expert4110 points
    The TAS1020B doesn't know that your codec isn't using MCLKO, so the switch from using MCLKO to MCLKO2 is invisible to it.
    This assumes that you're correct that your codec can use a master clock that is not related to the bitclock and wordclock, and responds appropriately to the bitclock and wordclock that the TAS1020B provides.
    So I don't think that change necessitates using asynchronous synchronization.
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on Jun 04 2012 18:40 PM
    Prodigy170 points
    Frank,
    Tried your suggestion, and it is promising. The headphone mode partially works with MCLKO set to 24.576MHz and MCLKO2 set to 19.2MHz, but there is some sync issue with MCLKO2. In function SoftPll(), it uses ACGCAPL and ACGCAPH to sync SOF with MCLKO (least 16 bits). Is there a similar register such as ACG2CAPL and ACG2CAPH for MCLKO2? Checking with Figure 2-1 of tas1020b.pdf, it shows that only MCLKO line has a 16-bit counter for SOF.
    I tried to use the same ACGCAPL and ACGCAPH to sync MCLKO2 with SOF in function SoftPll(), but it did not work. Here is what I did:
    Change SOF_EXPECTED_DELTA from 24576 to 19200, and use the MCLKO2 frequency value 0x7D0000 instead of 0x61A800.
    Alex
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on Jun 04 2012 21:33 PM
    Prodigy170 points
    I am going to try one thing here: use the same ACGCAPL and ACGCAPH to sync SOF with MCLKO2, but with the same ratio as MCLKO2/MCLKO (19.2MHz/24.576MHz). Hope this will solve the issue above.
    Report Abuse
    • Reply
  • Frank Minich
    on Jun 05 2012 07:12 AM
    Expert4110 points
    Alex,
    Why are you adjusting ACG2 based on SOF?
    The only reason to adjust ACG2 would be to try to obtain an output which was 'synchronized' with the host's (SOF) clock - but I've understood from what you've said previously that that's not a requirement.
    Frank
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on Jun 05 2012 13:44 PM
    Prodigy170 points
    Frank Minich
    Frank,
    What if I do need to adjust ACG2 to support the audio streaming between PC and TAS1020B and my codec? Is there a way to do it correctly? The ratio-sync of ACG2 based on ACGCAPL and ACGCAPH did not work.
    Alex
    Report Abuse
    • Reply
  • Frank Minich
    on Jun 05 2012 15:07 PM
    Expert4110 points
    Alex,
    What do you need MCLKO2 to be, relative to anything?
    Most TAS1020B users who want to use synchronous isochronous transfers adjust the ACG settings via softPll() to 'close the loop' - but that's immaterial if you don't need your codec's master clock to be somehow related to BCLK and WCLK.
    Frank
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on Jun 05 2012 18:04 PM
    Prodigy170 points
    Frank,
    My codec's master clock needs to be on 19.2MHz, but my codec is processing the same audio stream data coming from/going to PC via TAS1020B. In that case, shouldn't it be adjusted for PC host clock (SOF)?
    Alex
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on Jun 05 2012 18:31 PM
    Prodigy170 points
    Looks like the only way it might work for my case is to use asynchronous transfer? How does async streaming work with TAS1020B?
    Report Abuse
    • Reply
  • Alex Yin
    Posted by Alex Yin
    on Jun 05 2012 18:53 PM
    Prodigy170 points
    BTW, there might be a bug in file "SoftPll.c" function "softPllInit()": the first statement
        EngFrq = 0xA800;
    ACG frequency is 0x61A800. Since it only adjusts the 16 MSB of the fraction (total 18 bits), shouldn't it be like below?
        EngFrq = 0x6A00;
    It is only the initial value, so I don't think this will change much for my case. Just want to point out a potential bug in the code.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
