• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » AIC3204 Biquad LPF
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 6 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
AIC3204 Biquad LPF
AIC3204 Biquad LPF
This question is not answered
sam virgillo
Posted by sam virgillo
on Nov 13 2009 16:40 PM
Intellectual410 points
I am using the ezDsp C5505 runing the demo program (aic3204_loop_linein.c) that loops audio in and out to the headphones.
I have changed the sample rate to 8K and want to put a low pass filter on the input to the ADC.
I have loaded the coefficients into BiQuad A and enabled PRB_R2.  I think I followed the right sequence based on some of the other posts but t is still not filtering.
What did I miss?
Here is the code:
Int16 aic3204_loop_linein( )
    Int16 i, j;
    Int16 sample, data1, data2, data3, data4;
    /* Configure Serial Bus */
    SYS_EXBUSSEL |= 0x0100;  // Configure Serial bus 0 for I2S0
    /* Configure AIC3204 */
    AIC3204_rset( 0, 0 );      // Select page 0
    AIC3204_rset( 1, 1 );      // Reset codec
    AIC3204_rset( 0, 1 );      // Point to page 1
    AIC3204_rset( 1, 8 );      // Disable crude AVDD generation from DVDD
    AIC3204_rset( 2, 1 );      // Enable Analog Blocks, use LDO power
    AIC3204_rset( 0, 0 );      // Page 0
    /* PLL and Clocks config and Power Up  */
    AIC3204_rset( 27, 0x1d );  // BCLK and WCLK is set as o/p to AIC3204(Master)
    AIC3204_rset( 28, 0x00 );  // Data ofset = 0
    AIC3204_rset( 4, 3 );      // PLL setting: PLLCLK <- MCLK, CODEC_CLKIN <-PLL CLK
    AIC3204_rset( 6, 8 );      // PLL setting: J=8
    AIC3204_rset( 7, 15 );     // PLL setting: HI_BYTE(D)
    AIC3204_rset( 8, 0xdc );   // PLL setting: LO_BYTE(D)
    AIC3204_rset( 30, 0xB0 );      // BCLK=DAC_CLK/N =(12288000/48) = 256kHz = 32*fs
    AIC3204_rset( 5, 0x91 );   //PLL setting: Power up PLL, P=1 and R=1
    AIC3204_rset( 13, 3 );     // Hi_Byte(DOSR) 768
    AIC3204_rset( 14, 0 );  // Lo_Byte(DOSR)
    AIC3204_rset( 20, 0x80 );  // AOSR for AOSR = 128 decimal or 0x0080 for decimation filters 1 to 6
    AIC3204_rset( 11, 0x88 );  // Power up NDAC and set NDAC value to 8
    AIC3204_rset( 12, 0x82 );  // Power up MDAC and set MDAC value to 2
    AIC3204_rset( 18, 0x88 );  // Power up NADC and set NADC value to 8
    AIC3204_rset( 19, 0x82 );  // Power up MADC and set MADC value to 2
    AIC3204_rset( 0x51, 0x00 );// Power down Left and Right ADC
    AIC3204_rset( 0x3F, 0x14 );  // Power down left,right data paths and set channel
    AIC3204_rset( 61, 2 );    // PRB_R2
    // set biquad A to low pass fc = 3628
    AIC3204_rset( 0, 8 ); // Select page 8
    AIC3204_rset( 36, 0x6A ); // Left N0 H
    AIC3204_rset( 37, 0xC3 ); // Left N0 M
    AIC3204_rset( 38, 0x6F ); // Left N0 L
    AIC3204_rset( 40, 0x35 ); // Left N1 H
    AIC3204_rset( 41, 0x61 ); // Left N1 M
    AIC3204_rset( 42, 0xB7 ); // Left N1 L
    AIC3204_rset( 44, 0x00 ); // Left N2 H
    AIC3204_rset( 45, 0x00 ); // Left N2 M
    AIC3204_rset( 46, 0x00 ); // Left N2 L
    AIC3204_rset( 48, 0xD5 ); // Left D1 H
    AIC3204_rset( 49, 0x3C ); // Left D1 M
    AIC3204_rset( 50, 0x91 ); // Left D1 L
    AIC3204_rset( 52, 0x00 ); // Left D2 H
    AIC3204_rset( 53, 0x00 ); // Left D2 M
    AIC3204_rset( 54, 0x00 ); // Left D2 L
    AIC3204_rset( 0, 9 ); // Select page 9
    AIC3204_rset( 44, 0x6F ); // Right N0 H
    AIC3204_rset( 45, 0x96 ); // Right N0 M
    AIC3204_rset( 46, 0x52 ); // Right N0 L
    AIC3204_rset( 48, 0x37 ); // Right N1 H
    AIC3204_rset( 49, 0xCB ); // Right N1 M
    AIC3204_rset( 50, 0x29 ); // Right N1 L
    AIC3204_rset( 52, 0x00 ); // Right N2 H
    AIC3204_rset( 53, 0x00 ); // Right N2 M
    AIC3204_rset( 54, 0x00 ); // Right N2 L
    AIC3204_rset( 56, 0xD0 ); // Right D1 H
    AIC3204_rset( 57, 0x69 ); // Right D1 M
    AIC3204_rset( 58, 0xAD ); // Right D1 L
    AIC3204_rset( 60, 0x00 ); // Right D2 H
    AIC3204_rset( 61, 0x00 ); // Right D2 M
    AIC3204_rset( 62, 0x00 ); // Right D2 L
    /* DAC ROUTING and Power Up */
    AIC3204_rset( 0, 1 );      // Select page 1
    AIC3204_rset( 0x0c, 8 );   // LDAC AFIR routed to HPL
    AIC3204_rset( 0x0d, 8 );   // RDAC AFIR routed to HPR
    AIC3204_rset( 64, 2 );     // Left vol=right vol
    AIC3204_rset( 65, 0 );     // Left DAC gain to 0dB VOL; Right tracks Left
    AIC3204_rset( 63, 0xd4 );  // Power up left,right data paths and set channel
    AIC3204_rset( 0x10, 10 );  // Unmute HPL , 10dB gain
    AIC3204_rset( 0x11, 10 );  // Unmute HPR , 10dB gain
    AIC3204_rset( 9, 0x30 );   // Power up HPL,HPR
    USBSTK5505_wait( 100 );    // wait
    /* ADC ROUTING and Power Up */
    AIC3204_rset( 0x34, 0x30 );// STEREO 1 Jack
                               // IN2_L to LADC_P through 40 kohm
    AIC3204_rset( 0x37, 0x30 );// IN2_R to RADC_P through 40 kohmm
    AIC3204_rset( 0x36, 3 );   // CM_1 (common mode) to LADC_M through 40 kohm
    AIC3204_rset( 0x39, 0xc0 );// CM_1 (common mode) to RADC_M through 40 kohm
    AIC3204_rset( 0x3b, 0 );   // MIC_PGA_L unmute
    AIC3204_rset( 0x3c, 0 );   // MIC_PGA_R unmute
    AIC3204_rset( 0x51, 0xc0 );// Powerup Left and Right ADC
    AIC3204_rset( 0x52, 0 );   // Unmute Left and Right ADC
    USBSTK5505_wait( 100 );  // Wait
    /* I2S settings */
    I2S0_SRGR = 0x0;
    I2S0_CR = 0x8010;    // 16-bit word, slave, enable I2C
    I2S0_ICMR = 0x3f;    // Enable interrupts
    /* Play Tone */
  //  for ( i = 0 ; i < 8000 ; i++ )
    while ( 1 )
        for ( j = 0 ; j < 1000 ; j++ )
//            for ( sample = 0 ; sample < 48 ; sample++ )
            for ( sample = 0 ; sample < 8 ; sample++ )
                /* Read Digital audio input */
                data3 = I2S0_W0_MSW_R;
                  data1 = I2S0_W0_LSW_R;
                  while((RcvR & I2S0_IR) == RcvR)
                  data4 = I2S0_W1_MSW_R;
                  data2 = I2S0_W1_LSW_R;
                /* Write Digital audio input */
                I2S0_W0_MSW_W = data3;
                  I2S0_W0_LSW_W = 0;
                  //while((XmitR & I2S0_IR) == XmitR)
                  I2S0_W1_MSW_W = data4;
                  I2S0_W1_LSW_W = 0;
    /* Disble I2S */
    I2S0_CR = 0x00;
    return 0;
Thanks in advance, Sam
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • sam virgillo
    on Nov 13 2009 18:00 PM
    Okay.   Looked at the sample code in the design and configuartion guide and found what I did wrong.
    NDAC should = 2, MDAC should = 8, NADC should = 8 and MADC should = 12.
    Works like a champ now.
    Sam
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
