• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » PCM1792 - I/V-Stage-OP burns my fingers.
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 2 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 6 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 8 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is not answered
Frank Miketta12532
Posted by Frank Miketta12532
on Jun 14 2009 03:54 AM
Prodigy30 points
i´f build a DAC with PCM1792, OPA4134 (I/V-Stage) an LT1028 (unbalancer). It works and sound´s good.
My problem: The OPA4134 in the I/V-Stage heats up and after a few seconds it burns my finger. The Stage is build like the schematic in the datasheet with R 750 Ohm and C 2200p. On BPZ i have -4.4V over the resistors and at the output-lines. The OPA4134 drives in this state 4x 5.8mA.
Is the heating ok and i have to cool them down or is here a failure in my schematic?
Best regards
Frank
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Frank Miketta12532
    on Jun 15 2009 15:26 PM
    Prodigy30 points
    Additional informations:
    The current of the OPA4134 is 60mA on the -15V and 12mA on the +15V Rail.
    Each amp of the OPA4134 drives 12mA on BPZ.
    Thats IMHO all seems to be OK, i wonder about the heating of the i/v-Stage......
    Best regards
    Frank
    Report Abuse
    • Reply
  • Joseph Wu
    Posted by Joseph Wu
    on Jun 19 2009 13:26 PM
    Genius14210 points
    Frank,
    The temperature can definitely get warm on these devices, but how warm depends on the operating point of the output. For example if V+ is sourcing 12mA and and the V- is sinking 60mA, and the output is at 0V, then the total dissapation is (12mA*15V)+(60mA*15V)=1.08 Watts. Now looking at the thermal resistance of the part (on the bottom of page 2 of the datasheet) it is 110C/W from the die junction to ambient temperature.
    This means that the temperature will rise from the ambient by 1.08W*110C/W=119C. Just enough to burn your fingers.
    If the output is less than 0V, then less of the power is dissipated by the package and more is dissipated by the load.
    Joseph Wu and Marek Lis
    Report Abuse
    • Reply
  • Joseph Wu
    Posted by Joseph Wu
    on Jun 22 2009 13:02 PM
    Genius14210 points
    Frank,
    Are you really trying to drive 12mA per op-amp? It's a lot to be sourcing (or sinking if it's coming from V- supply).
    You really should try to reduce the current especially if the temperature is getting close to the 150C limit.
    Joseph Wu
    Report Abuse
    • Reply
    on Jun 22 2009 16:56 PM
    Prodigy30 points
    Hello Jospeh,
    thank you for your reply.
    The schematic is nearly in the datasheet from the pcm1792 page 35:
    http://www.ti.com/lit/gpn/pcm1792a
    So i wonder about the current and the temperatur.
    Now i have fixed heatsinks on the op-amps (13K/W) and the tempertur is at ~50°C. Tomorrow we will install the DAC in our test car, the i will try to reduce the current.
    Reguards
    Frank
    Report Abuse
    • Reply
  • Joseph Wu
    Posted by Joseph Wu
    on Jun 23 2009 17:31 PM
    Genius14210 points
    Frank,
    Just to make sure, I'll just contact you directly.
    Joseph Wu
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
