Hi ALL,
Finally we are able to do some improvement in our codec , Now we are able to generate beep (exactly 2khz by programming beep registers with values from this link http://www.ti.com/lit/an/slaa446/slaa446.pdfexample-3.4 ) . but still we are not able to get any audio in HPL and HPR line (but getting some noise).
In my case codec is slave and cpu is master. here is my clock configuration
MCLK=5.6448MHZ
BCLK=1.411MHZ(for 16 bit word size)
WCLK=44.1KHZ.
we programmed the dosr,p,r,j and d value accordingly as mentioned in the data sheet.
I tested the data in from cpu to codec by playing the wav file which contains only 'A5' data. Here i am attaching logic analyser output, feels DataIN is ok and also attaching register dump of codec chip set while playing the audio.
I Posted in TI forum but not get any reply, Kindly look at my codec register dump and tell me what will be the issue.Your help will be greatly appreciable.
