Audio codec PCM2706 interfacing with Beagle bone black Am3358
Other Parts Discussed in Thread: PCM2706, TUSB2077A
I am working on a project in which i am using Beagle bone black Am3358 ,along with it i am using PCM2706 Audio DAC with USB interface.
I had done the interfacing properly,but unfortunately my PC is unable to detect the same.
I tried on Win XP & Linux both but its not detecting.
Kindly share your valuable suggestions for the same.
If required ,i can share my schematics too.
thanks,
utpal
  • Hi Utpal,
    Let me take a look on this, I will be back to you as soon as possible.
    Iván Salazar
    Texas Instruments
  • Thanks for you reply Ivan
  • Hi Utpal,
    Let me ask in detail:
    - Could you please share your schematics? You can send me an email with the files to ivan.salazar@ti.com
    - The interface with Beagle Bone Black was ok, so you're now trying with a PC?
    - Have you tried with 7?
    Iván Salazar
    Texas Instruments
  • Hi Utpal,
    Thank you for the information. I need to ask you something else:
    I see that you are using TUSB2077A as a HUB with 5 devices connected; when you connect these to the PC, is the PC unable to detect any of these devices? or is it unable to detect only the PCM2706?
    Your hardware configuration for the PCM2706 seems to be fine so this make me think that the problem could be the compatibility of TUSB2077A.
    Could you connect the PCM2706 directly to the PC? We need to know if the problem is in the PCM2706 or in the TUSB2077A.
    Iván Salazar
    Texas Instruments
