I am using the AIC26 for an audio app. I am using the left and right high power outputs in a capacitorless bridge mode. It works fine with no spectral shaping using the example in the data sheet.
I have attempted to use the Biquad filter calculator to create a Butterworth 1st order low pass filter at 3.6KHz. I put the calculated numbers into the associated registers, but get no output. Am I writing the wrong registers, or wrong numbers? The filter is activated, and I even tried inverting the right channel numbers.
Any help would be greatly appreciated.
