Hi:
My Tlvaic3104 link AM335x by i2c2,macasp0,i have finished the init of i2c2 and macasp0,But when i aplay the 123.wav,it failed,the log is :
root@am335x-evm:/test# aplay 123.wav
[ 3105.665283] +++++++++zhouqun:davinci_mcasp_startup
[ 3105.670440] ++++++++zhouqun:davinci_pcm_open
[ 3105.675048] +++++++zhouqun:allocate_sram
[ 3105.679229] ++++++++zhouqun:davinci_pcm_dma_request
Playing WAVE '123.wav' : Signed 16 bit Little Endian, Rate 44100[ 3105.692047] ++++++++zhouqun :davinci_mcasp_set_dai_fmt
Hz, Stereo
[ 3105.697937] +++++++=zhouqun:daifmt :1000d++++++++++davinci_mcasp_hw_params
[ 3105.707550] ++++++++++++zhouqun :davinci_hw_common_param
[ 3105.713226] ++++++++zhouqun :davinci_hw_param
[ 3105.717864] +++++zhouqun :davinci_config_channel_size
[ 3105.723266] +++++++zhouqun:davinci_pcm_hw_params
[ 3105.730438] +++++++++zhouqun:davinci_pcm_prepare
[ 3105.735412] ++++++zhouqun:davinci_pcm_enqueue_dma
[ 3105.740447] ++++++zhouqun:davinci_pcm_enqueue_dma
[ 3105.746215] +++++++++zhouqun:aic3x_set_power
[ 3105.769927] +++++++zhouqun:davinci_pcm_trigger
[ 3105.774658] +++++++++zhouqun:pcm_cmd = 1
[ 3105.778839] ++++++++++++zhouqun:davinci_mcasp_trigger
[ 3105.784210] +++++++++zhouqun:mcasp_cmd = 1
[ 3105.788574] +++++++++zhouuqn :davinci_mcasp_start
[ 3105.793548] ++++++++++zhouqun:mcasp_start_tx
[ 3105.798095] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3105.802734] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3105.808288] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3105.812896] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3105.818450] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3105.823059] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3105.828613] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3105.833221] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3105.838775] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3105.843383] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3105.899993] +++++zhouqun:davinci_pcm_pointer
aplay: pcm_write[ 3115.903869] +++++++zhouqun:davinci_pcm_trigger
[ 3115.909576] +++++++++zhouqun:pcm_cmd = 0
[ 3115.913726] ++++++++++++zhouqun:davinci_mcasp_trigger
[ 3115.919097] +++++++++zhouqun:mcasp_cmd = 0
[ 3115.923461] ++++++++++++====zhouqun :davinci_mcasp_stop
[ 3115.929016] ++++++++++++zhouqun: mcasp_stop_tx
:1710: write err[ 3115.935058] +++++++zhouqun:davinci_pcm_hw_free
or: Input/output[ 3115.939910] +++++++zhouqun:davinci_pcm_hw_free
error
[ 3115.948822] +++++++++++zhouqun:davinci_pcm_close
when i aplay -N 123.wav the log is :
[ 3191.979583] +++++++=zhouqun:daifmt :1000d++++++++++davinci_mcasp_hw_params
[ 3191.989227] ++++++++++++zhouqun :davinci_hw_common_param
[ 3191.994934] ++++++++zhouqun :davinci_hw_param
[ 3191.999542] +++++zhouqun :davinci_config_channel_size
[ 3192.004943] +++++++zhouqun:davinci_pcm_hw_params
[ 3192.012054] +++++++++zhouqun:davinci_pcm_prepare
[ 3192.017028] ++++++zhouqun:davinci_pcm_enqueue_dma
[ 3192.022064] ++++++zhouqun:davinci_pcm_enqueue_dma
[ 3192.027801] +++++++++zhouqun:aic3x_set_power
[ 3192.051330] +++++++zhouqun:davinci_pcm_trigger
[ 3192.056091] +++++++++zhouqun:pcm_cmd = 1
[ 3192.060241] ++++++++++++zhouqun:davinci_mcasp_trigger
[ 3192.065612] +++++++++zhouqun:mcasp_cmd = 1
[ 3192.069946] +++++++++zhouuqn :davinci_mcasp_start
[ 3192.074951] ++++++++++zhouqun:mcasp_start_tx
[ 3192.079467] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3192.084106] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3192.089660] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3192.094268] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3192.099792] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3192.104431] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3192.109954] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3192.114593] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3192.120117] ++++++++zhouqun:mcasp_set_ctl_reg
[ 3192.124755] +++++++++zhouqun:(mcasp_get_reg(regs) & val
[ 3192.181427] +++++zhouqun:davinci_pcm_pointer
[ 3192.286651] +++++zhouqun:davinci_pcm_pointer
[ 3192.391357] +++++zhouqun:davinci_pcm_pointer
[ 3192.496368] +++++zhouqun:davinci_pcm_pointer
[ 3192.601074] +++++zhouqun:davinci_pcm_pointer
[ 3192.706359] +++++zhouqun:davinci_pcm_pointer
[ 3192.811065] +++++zhouqun:davinci_pcm_pointer
[ 3192.916076] +++++zhouqun:davinci_pcm_pointer
[ 3193.020782] +++++zhouqun:davinci_pcm_pointer
[ 3193.125854] +++++zhouqun:davinci_pcm_pointer
[ 3193.230560] +++++zhouqun:davinci_pcm_pointer
[ 3193.335510] +++++zhouqun:davinci_pcm_pointer
[ 3193.440216] +++++zhouqun:davinci_pcm_pointer
