Dear TI-san.
I have two question(or requirement) about PCM1864.
It will attach a document that will provide detailed information.
Quetion1:
Our use condtion as follows.
・Analog input 4-ch(single-ended mic input for array-mic), External analog input 2-ch(L/Rch).
In 4-ch array-mic, We need sampling at the same timing (LRCLK same Edge).
・Audio output I2s I/F using TDM-mode.
In our use condtions, Could you tell us the recommended about these input connections to pcm1864 analog inputs?
Please see the attached file for details.
Question2:
About Serial Audio Interface Timing
In datasheet(SLASE55A, page50), Figure45, there is describe audio data format by timing chart.
We would like to know also about TDM-mode. Could you provide us the data format of TDM-mode?
Muraki Kazuo.
