Hi team,
We could successfully build the following two setups on the PurePath.
But there are some error messages when we combine these two setups (show as below)
How can we fix this issue?
Generating code for base_main_Rate48 .. assembling ...MemoryType usage: miniDSP_A_coeff: 155, miniDSP_A_data: 217, miniDSP_A_instr: 377, miniDSP_A_instr_alloc: 389, miniDSP_A_cycles: 324, miniDSP_A_cycles_alloc: 904,miniDSP_D_coeff: 309, miniDSP_D_data: 108, miniDSP_D_instr: 1082, miniDSP_D_instr_alloc: 1086, miniDSP_D_cycles: 691, miniDSP_D_cycles_alloc: 897
Assembly failed
Error: (0): Memory size exceeded : miniDSP_D Instruction Memory exceeded by 62 words.
1 error detected
Assembler was terminated.
Summary: 0 Error(s)
Code generation terminated on base main Rate48
Build failed.
