• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » DFU issues on TAS1020B
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 2 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 6 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 7 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is answered
David Schimon
Posted by David Schimon
on Jun 17 2009 15:36 PM
Prodigy20 points
Hi-
I'm trying to do some USB development on the TAS1020.  All the documentation in the Firmware Development Kit/Datasheet/UG indicate that the process ought to be the following:
1.   Remove EEPROM chip (or short SDA or something) to initiate a host boot
2.  Plug in the device, which will enumerate with a dummy VID/PID (0xFFFF and 0xFFFE).
3.  Use the TI DFU software to download a properly formatted file to the device/EEPROM.
Well, my problem lies in between steps 2 and 3.  After shorting out the EEPROM, I plug in the device and am unable to locate acceptable drivers.  The device describes itself as "Unknown" manufacturer and product, and the DFUUSB.inf and DFUUSB.sys files packaged in the DFU_Software portion of the downloadable Firmware dev kit don't seem to cut the mustard.  I can point the driver install directly to them or even select the inf file, but the installation never works.  What's more, I've watched the data come across a bus analyzer, and the correct VID/PID come across, it's just that there is nothing on the other side waiting for it.
The 1020EVM guide (a guide for an old eval board for the product) indicates that there was once a 3.5" driver floppy or something that contained drivers and a file called "DFU.EXE" which does not make an appearance in the FDK.
Ther eis a DFUTEST.EXE, but it always fails to recognize a DFU device.
I'm stuck.  Any thoughts?
-David Schimon
Embedded Systems Engineer
TAS1020B USB DFU TAS1020 TAS1020A
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Eto Demerzel
    Posted by Eto Demerzel
    on Jun 30 2009 05:52 AM
    Prodigy20 points
    I need this too.
    I have an M-Audio Ozone, that's a midi keyboard controller with audio interface. And I think that is Bricked... (now... previously I replaced the tas1020a on it) windows detect it as Unknown. I guess that is in dfu mode waiting for a firmware but i can find a way to install a dfu driver. There are no support for this in M-Audio, no firmware updates.
    Report Abuse
    • Reply
  • Eto Demerzel
    on Jun 30 2009 06:34 AM
    Prodigy20 points
    I have an M-Audio Ozone, that's a midi keyboard controller with audio interface. And I think that is Bricked... (now... previously I replaced the tas1020a on it :S) windows detect it as Unknown. I guess that is in dfu mode waiting for a firmware but i can find a way to install a dfu driver, I tried the firmware developer kit's driver . There are no support for this in M-Audio, no firmware updates.
    Report Abuse
    • Reply
  • Shareef Jalloq
    Posted by Shareef Jalloq
    on Aug 11 2009 06:29 AM
    Prodigy150 points
    David, I just wrote a long reply to this but the forum ate it.
    Have a look at this link for debugging driver installation:  http://www.microsoft.com/whdc/driver/install/setupapi.mspx
    Try editing the following lines in the INF:
    [Manufacturer]
    %MfgName%=Texas Instruments
    and changing them to:
    [Manufacturer]
    %MfgName%=TexasInstruments
    According to all the doco I've read on INF's so far there shouldn't be a space on the RHS.  This needs to match the models-section-name in the INF so that the installer knows which drivers to install.  My theory is that it isn't finding any relevant driver to install.  However, this would mean that the driver has been broken for 9 years and not been fixed which I can't believe.
    Could you update the thread with any progress you make as I'm going to be following this path soon.
    Cheers, Shareef.
    Report Abuse
    • Reply
  • Shareef Jalloq
    on Aug 11 2009 08:58 AM
    Prodigy150 points
    OK, I've spoken to 3 colleagues about the syntax now and they all agree that this looks like a typo in the INF file.  If possible could a TI representative step in and confirm.
    It would also be good to know if there is a more recent pdf for the Firmware DK which has all the placeholders filled and would give me a little more confidence that the contents are correct.  It looks like the first draft from the engineer rather than the finished document.
    Thanks.
    Report Abuse
    • Reply
  • David Schimon
    on Aug 11 2009 14:14 PM
    Prodigy20 points
    Shareef-
    Actually, after I posted this question, I contacted TI support.  They quickly provided me with a new set of drivers- which worked.  I noted that after I made the inquiry, the FDK download was taken down for some period, so it's possible that they've updated the installer.  I'd suggest sending them an email requesting it, or if you don't mind using a file some guy on the internet gives you, I'd be happy to send you the driver they gave me.  I'm pretty sure I have the original zip file somewhere around here..
    --David Schimon
    Report Abuse
    • Reply
  • Shareef Jalloq
    on Aug 11 2009 15:47 PM
    Prodigy150 points
    Hi David,
    ok, brilliant.  I'd actually appreciate hearing how you've got on with the part as well as getting hold of the drivers.  Drop me a line on sjalloq_at_hotmail_dot_com.
    Thanks.
    Report Abuse
    • Reply
  • Tuan Luu
    Posted by Tuan Luu
    on Sep 23 2009 21:23 PM
    Verified Answer
    Verified by Don Dapkus
    Mastermind25875 points
    Sorry, just now saw the question on DFU.  Please see attached for the correct .inf  The one on FDK will be fixed shortly.
    Thank you,
    Tuan7444.dfu.zip
    Audio Applications
    Texas Instruments, Inc.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
